Old 11-21-2009, 04:15 PM   #1
Standardidiot
Standardidiot is an unknown quantity at this point
Ultimate sr20det BUILT swap package
I have been working on my s14 for some time now and I just happen to change my mind on my motor setup, after I fully built an sr20det with all the bells and whistles. I'm looking to sell the motor tranny wiring harness and ecu as a kit.
Motor Specs
Engine Mods
Crank magna-fluxed and polished
Engine block bored .020 , honed, decked, washed
CP pistons
Brian Crower Rods
ACL Race Rod, Main and thrust
ARP Head Studs
Cometic Metal Head gasket
Moroso Oil Pan
OEM Engine Gasket Kit
Cylinder head decked and washed
5 angle valve job
New valve guides
Brian Crower Valve springs and Titanium Retainers
Port and polish
Intake and exhaust manifolds and gaskets port matched
Brian Crower stage 2 cams
Titek Adjustable Cam gears
garret gt2871r .86
Cams degreed to true TDC
xs power exhaust manifold
Rebuilt Alternator
Rebuilt Starter
Meagan Aluminum pulleys
Circuit sport oil feed and water lines
Powder coated Valve cover
Stock intake manifold glass bead blasted inside and out
Motor fully balanced
act lightweight flywheel
Rps Clutch
New oem water pump
This motor has been properly built, as you can see by the attention to detail in the pictures.
Stock 5 speed trans, cleaned and painted black
Wiring harness professionally redone by Wiring specialties.com
Stock ecu
PS pump, ac compressor also included
Will include Drive shaft shop one piece steel drive shaft and all extra and oem sr20det Parts I have.
Asking $5500 obo, and just because I put obo, don't low ball me please.
Will also accept an ls2 motor trans and harness, or something comparable for trade.
shipping will be at buyers expense, if driving distance is within and hour or too, I can meet.
Standardidiot is offline
