Old 06-12-2003, 11:19 AM   #1
Bbandit
Bbandit's Avatar
Bbandit is an unknown quantity at this point
Send a message via ICQ to Bbandit Send a message via AIM to Bbandit
Question easiest way to roll fenders
yes.. my tires rubbed my fenders.. prolly cuz i set my coilovers too low.. i dont want to set the coilovers any higher because IMO, this setup is just perfect..
now.. do you guys know the easiest way to roll fenders?
i heard you can use metal baseball bat..
but i dont have the guts to do it.. i might mess up the body work..
any suggestions or opinions?
i think im going to get myself a 1 inch diameter metal pipe and try to roll the fender myself..
right now i have one finger gap between my tires and my fenders
==>>TGL GARAGE<<==.. RIP!
S13 coupe KA-T @ 0.5 Bar = SOLD!
A31 Cefiro + SR = Current
Bbandit is offline   Reply With Quote
Old 06-12-2003, 11:36 AM   #2
the head
the head's Avatar
i use a wooden baseball bat because there is less chance of scratching the edge not the easiest but by far the cheapest
Old 06-12-2003, 03:10 PM   #3
Jsquared
Jsquared's Avatar
Jsquared is an unknown quantity at this point
SAWZALL.
oh wait, you just wanted to roll them baseball bat should work fine, if you don't have enough room at your current ride height, trying jacking the car up enough for the fender gap to just fit the bat in but without lifting the wheel off the ground...
1992 SR coupe, ~11psi
a.k.a. "Zip-Tie"
www.carolinanissans.com
Jsquared is offline   Reply With Quote
Old 06-12-2003, 03:59 PM   #4
fooddude
fooddude's Avatar
fooddude is an unknown quantity at this point
Send a message via AIM to fooddude
A 1 inch pipe?? I think a baseball bat is safer cuz a 1" dia pipe is too small and easier to leave a small sharp outie dent, whereas a bat is bigger and more spread out and wouldn't be as sharp...did that make any sense? Whatever
fooddude is offline   Reply With Quote
Old 06-12-2003, 06:05 PM   #5
RBS14
RBS14's Avatar
RBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura about
It depends on how good you want your body panels to look. My friend and i rolled his fenders SLOWLY with a wood baseball bat. It did roll them but when you looked hard you could see the fender had been slightly pulled and subsequently reshaped. That is why there are special fender rolling tools that won't pull ur fenders. But like i said, if you don't care, just use a bat.
RBS14 is offline   Reply With Quote
Old 06-12-2003, 07:01 PM   #6
Bill Roberts
Bill Roberts is an unknown quantity at this point
Would it not be better to press it by making a wooden template and a support base taking the fender off and using a hydrolic jack to slowly press it into the roll....I guess the bat it;s cool...but one wrong strike, and whammoo.....fuc ked up fender.
Bill Roberts is offline   Reply With Quote
Old 06-12-2003, 07:18 PM   #7
Bbandit
Bbandit's Avatar
Originally posted by Bill Roberts
Would it not be better to press it by making a wooden template and a support base taking the fender off and using a hydrolic jack to slowly press it into the roll....I guess the bad it cool...but one wrong strike, and whammoo.....fuc ked up fender.
exactly! thats why i said i dont have the guts to do it..
however.. i WANT to do it..
btw.. im only rolling my rear fenders.. the fronts are alright
oh well.. i guess my best bet is to just bring it to some body shop
Old 06-12-2003, 07:28 PM   #8
Bill Roberts
I got an idea!!!...take tin snips and cut about 3 inches apart on the lip. Take a small ball peen hammer and gently tap it (or hard rubber mallet) to turn it down. If too thick (havent done it actually) take a hack saw and cut the grooves...work the metal ever so slightly to curve them in.
Be sure to paint the $hit out of the cuts to keep them from rusting out.
Think that will work???? cool>???
Old 06-12-2003, 07:58 PM   #9
SilviaDriver
SilviaDriver's Avatar
SilviaDriver will become famous soon enoughSilviaDriver will become famous soon enoughSilviaDriver will become famous soon enoughSilviaDriver will become famous soon enough
Send a message via AIM to SilviaDriver
go to a shop to do it.
or this..
it can be had for only $350
after u buy that..go out and offer to do it for people at 25 bucks [usually 50 bucks a fender] and the thing will pay itself off over time.
SilviaDriver is offline   Reply With Quote
Old 06-12-2003, 08:32 PM   #10
Bill Roberts
Fender roller tool...yep, I should have known...really..
Damn, is their anything we can't do to a cars? I feel the 240SX and all the compentant people out there make it the granddaddy of car knowledge of cars to own.
(hey, my transmission suspension damper, I applied off a 84 4WD nissan king cab is no joke)
Old 06-12-2003, 09:14 PM   #11
timmybgood
timmybgood is an unknown quantity at this point
if you wanna do it cheap, do the baseball bat method, but make sure you use a heat gun, or the paint WILL CRACK. take it very slow, and may the force be with you
its really not that hard, just take your time
1995 SE
timmybgood is offline   Reply With Quote
Old 06-12-2003, 10:39 PM   #12
NismoGear5
NismoGear5 is an unknown quantity at this point
here is a link I saw somewhere. here
It shows how someone uses a baseball bat to roll his/her fenders. Looks good, I may try it.
p.s I owned in automodelista hehehe :hammer:
here is the link.
http://www.vtec.net/articles/view-ar...rticle_id=3511
NismoGear5 is offline   Reply With Quote
Old 06-12-2003, 10:41 PM   #13
legendarysnail
legendarysnail is an unknown quantity at this point
Had a major brain fart....
Anyone care to explain to my slow self what fender rolling actually is? Heard about it so many times but never quite understood.
Man run in front of car, man get tired. Man run behind car, man get exhausted.
*** 1993 240sx SE Coupe ***
> Mercedes-Benz ML320 sidemarkers
> Sleepyeye switch
> Front strut bar
> Cone intake
> Gutted trunk
> Headlight conv
> Mufflerless
> Hella foglights
legendarysnail is offline   Reply With Quote
Old 06-13-2003, 11:44 AM   #14
Bbandit
Bbandit's Avatar
here is the link.
looks so easy..
its been a long time since i played automodelista.. maybe i should start again..
legendarysnail: click that link.. you'll know what it means
