Old 04-19-2010, 11:15 PM   #1
scooby steve33
scooby steve33 is making his/her stupidity well-knownscooby steve33 is making his/her stupidity well-knownscooby steve33 is making his/her stupidity well-knownscooby steve33 is making his/her stupidity well-known
Rucas with lots of negative camber
I am in the process of getting my car to a roller however im running into a problem in the rear suspension. I understand the point of adjustable ruca however i have read up that most of them are to "fix" the problem or bringing it as close to zero as they can. My PBM are are rubbing the coilover and im putting the stock arms back on. Im going to need a LOT or rear camber so the question is arm there any aftermarket arms that will allow for a lot of rear camber? in the neighborhood of -4/-5 or more?
SPARK NOTES
PBM ruca is rubbing
stock arm is back on
need at least -5 degrees
what Rucas should i buy if any?
scooby steve33 is offline   Reply With Quote
Old 04-19-2010, 11:30 PM   #2
landins13
landins13's Avatar
landins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choices
why the hell do you need -5 degrees? PBM makes some of the best parts around and ive seen rediculous camber and ride height on their parts without problem. Are you sure the RUCA is the problem and not something else making the whole setup worse
NO HANDS IN PANTS!!
landins13 is offline   Reply With Quote
Old 04-19-2010, 11:41 PM   #3
s13 @ fullboost
s13 @ fullboost's Avatar
s13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfection
Send a message via AIM to s13 @ fullboost
yeah I doubt the ruca is the problem post some pics of your situation so we can see whats going on.
s13 @ fullboost is offline   Reply With Quote
Old 04-20-2010, 01:08 AM   #4
!Zar!
!Zar!'s Avatar
Why not just run the stock ruca?
Old 04-20-2010, 04:29 AM   #5
inertiadrft
inertiadrft's Avatar
Location: Straight Repp'n the FIVE-SIX-TWO and now The NINE-5-ONE
inertiadrft has much to be proud ofinertiadrft has much to be proud ofinertiadrft has much to be proud ofinertiadrft has much to be proud ofinertiadrft has much to be proud ofinertiadrft has much to be proud ofinertiadrft has much to be proud ofinertiadrft has much to be proud ofinertiadrft has much to be proud ofinertiadrft has much to be proud ofinertiadrft has much to be proud of
Send a message via AIM to inertiadrft
I think your problem is that you possibly have s14 PBM rucas on a S13?
Thats what im guessing? If so, then yea it will rub..
http://zilvia.net/f/s-chassis/254456...ce-issues.html
inertiadrft is offline   Reply With Quote
Old 04-20-2010, 06:19 AM   #6
Csomme
Csomme is an unknown quantity at this point
Pbm rucas have clearance issues with some brands of coilovers. That is probably your problem
Csomme is offline   Reply With Quote
Old 04-20-2010, 08:01 AM   #7
scooby steve33
yeah thats what ive heard and im runnging old hks coilovers that are really big around so i think thats part of it. ill try to get some pictures of the situtation but i already put the stock arms back on
