![]() Join Date: Jan 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
![]() Well i went to the mercedes dealership and they had some ml320 sidemarkers in stock. I took a look at um and they look nice, except the reflector/lense part is yellow inside. So the housing is white, but i think it stays on as yellow because the bulb inside is white. I've never actually seen them before? how do they look? Is it possible to make them completely clear?
Or is there another sidemarker that looks completely clear and fairly rectangular / white(clear) and about the same or close to length as the stock s13 sidemarker? what about this c32 marker? http://mercedes-auto-and-parts.com/a...s---67529.html |
![]() Join Date: May 2002
iirc, legally it shoudl be amber
only white should emit from the front of you car (or reverse lights only for rear) the rest should be amber...but rear sidemarkers i think have to be red. with white, you run a higher risk of getting hassled by the police... check the vehicle code for verification. |
Yes they look good amber, but if you want them to be clear just break the amber surrounding inside of the lenses and take it out by pieces. That's what it did, used needle nose pliars.
But yes clear side markers are illegal as well as turn signals, they have to be either amber or red. |
just wanted to make sure you knew about the write up...
http://www.zilvia.net/installs/ml320/doc.asp here's a pic of 'em on my car. put them to the rear of the fender. good location i think, but wherever works. http://www.imagestation.com/picture/...d.jpg.orig.jpg & http://www.imagestation.com/picture/...c/fd78934f.jpg |
If you do decide to shave down the fender, I suggest using a dremel. I used a circular file and kept getting high points in the hole, so it took me a longass time.
You could always take out the amber lense thing and use 194 LED's that emit amber...that'd look cool and be legal ![]() Here's my car: ![]() ![]() ![]() I no longer have the clear bumber lights, but it looks badass with them!
Man run in front of car, man get tired. Man run behind car, man get exhausted. *** 1993 240sx SE Coupe *** > Mercedes-Benz ML320 sidemarkers > Sleepyeye switch > Front strut bar > Cone intake > Gutted trunk > Headlight conv > Mufflerless > Hella foglights Last edited by legendarysnail; 07-08-2003 at 11:55 AM.. |
