Old 07-15-2003, 12:31 AM   #1
jamik_69
jamik_69 is an unknown quantity at this point
Send a message via ICQ to jamik_69 Send a message via AIM to jamik_69
z32 rear breaks with 4 bolt?
hi i rember a while ago a guy did a full z32 brake install and kept the four bolt hubs does anyone have a link or any info that would be great
thank you
1990 240sx coupe
jamik_69 is offline   Reply With Quote
Old 07-15-2003, 07:21 AM   #2
Dousan_PG
Dousan_PG's Avatar
all u have to do is redrill the rotors to 4 lug
its not rocket science
Aaron
Pink GodziRa
Old 07-15-2003, 01:18 PM   #3
jamik_69
well then you have to deal with the calipers and the e-brake line do the calipers bolt right on do you have to change master cylinders? its more then just re-drilling the rotors
1990 240sx coupe
Old 07-15-2003, 01:23 PM   #4
Dousan_PG
Dousan_PG's Avatar
ya hcnage the MC for best response and balance
you will need to fab/customize the brake lines
www.projectsilvia.com should have a 'conversion' set for sale soon, check their site (might already be selling?)
Aaron
Pink GodziRa
Old 07-15-2003, 01:32 PM   #5
Kid Zelda
Kid Zelda is an unknown quantity at this point
Send a message via AIM to Kid Zelda
The Z32 calipers will mount to the spindles w/o a problem.
You might want to get some new brake lines made for this application, no very necessary, but recommend. www.takamotorsports.com sells them
The M/C can be left alone, but it will feel sluggish, change to the Z32 if you want to feel the full-force response of the Z32 M/C.
The e-brake line is not as hard as one would think, you can use come steel line clamps, it'll work and be safe, I used 3 on each line, total of 6 just to be on the safe side. It will work for the moment, until you buy the projectsilvia conversion, which is nice ... but .. Whatever...
Kid Zelda is offline   Reply With Quote
Old 07-15-2003, 01:46 PM   #6
sykikchimp
WOW addicted
sykikchimp's Avatar
For some reason, I was under the impression that in order to have an ebrake with 300zx rears, you had to go 5-lug because the ebrake was built into the rotor hat? is this not the case?
Old 07-15-2003, 01:48 PM   #7
Dousan_PG
Dousan_PG's Avatar
when i took apart my hub from spindle (still had drum on it) seems you could stay 4 lug and do it. i am pretty sure drift freaq might know more.
to me, from what i saw, you could stay 4 lug, the hub was separate from the internal drum setup and soforth
Aaron
Pink GodziRa
Old 07-15-2003, 01:58 PM   #8
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
the e-brake assembly is on the dust sheild, which bolts between the hub and the spindle.
AceInHole is offline   Reply With Quote
Old 07-15-2003, 08:51 PM   #9
old_s13
old_s13's Avatar
old_s13 is an unknown quantity at this point
On the S13, brake bias is off w/ the OEM MC.
old_s13 is offline   Reply With Quote
Old 07-16-2003, 01:03 PM   #10
AceInHole
Autox Technician
AceInHole's Avatar
isn't there a small adjustment screw? the philips head "screw" at the end of the z32 MC (and IIRC the z32 and S13 MC's had a similar layout) looks like it regulates rear brake bias.
I'd look up the S14 MC but my FSM is in my car
Old 07-16-2003, 04:27 PM   #11
sykikchimp
WOW addicted
sykikchimp's Avatar
ace - r u talking about this screw here:
