Old 07-12-2003, 10:27 PM   #1
kandyflip445
kandyflip445's Avatar
Stupid Oil Leak!!!!!
Well I knew I had a oil leak before I changed my oil today. I got some GUNK to flush it out (and to kinda make the leak more apparent). I poured the GUNK in the engine and.....IT WAS LEAKING OUT PRETTY QUICK!!!! About a shot glass (for lack of measurment) came out. So I started the car, ran it the five minutes, drained my oil, changed the filter, and filled up the oil again. I checked the dipstick, full. Started the engine, ran it for about 5 more minutes. I spotted some dripping from the oil pan. Problem is that it's not from the oil pan or seal. It's from up higher. I tried lookin around but it's useless. It looks as if there has been a leak for quite some time and it hasn't been takin care of. So, I plan on driving it and washing out the engine bay then looking for the leak again. Any pointers on finding it would be helpfull. Oh....and now there is a ticking noise from the front of the engine where the timing chain is..... ... Oh, well. I guess I would have had to fix it sometime. It goes with the RPM of the engine and can't be heard after a certain RPM.
GO MAINTENANCE!!!!!
My 240 vBgarage
Old 07-12-2003, 11:56 PM   #2
twitchy
twitchy's Avatar
twitchy is an unknown quantity at this point
carefully clean the lower side of the engine bay with a heavy duty degreaser to get the oil and gunk off, this may help you spot the leak easier when more comes out...dont do it on your driveway though.
Who the hell needs a sig anyhow
twitchy is offline   Reply With Quote
Old 07-13-2003, 10:26 AM   #3
kandyflip445
I was gonna wash out the entire engine bay....
My 240 vBgarage
Old 07-13-2003, 01:13 PM   #4
Bill Roberts
Bill Roberts is an unknown quantity at this point
Look at the oil sending unit...
Mine did this..that sending unit was the problem. Replace it. 15 bucks.
Bill Roberts is offline   Reply With Quote
Old 07-13-2003, 01:30 PM   #5
Tubed4evr
Tubed4evr is an unknown quantity at this point
Basically there are like three places it could be leaking from if its not the oil pan and it is coming from the front. The valve cover (very easy to spot), the timing chaing cover, or the front main seal. I replaced my front main over the winter and it wasnt too bad. Just start from the top and work your way down. My money is on the front main seal. Both me and my brother (95 SE) have replaced ours in the last 6 months so it seems like a common problem on the 240. Good luck.
Ryan
Tubed4evr is offline   Reply With Quote
Old 07-13-2003, 02:17 PM   #6
misnomer
misnomer's Avatar
I had a leaky main seal as well. Not too tough to get to.
Make sure you pinpoint the problem beforehand, though.
Old 07-14-2003, 10:44 PM   #7
kandyflip445
There is oil(residue) on top of the PS pump so I don't know if the front oil seal would be it... I will check that though. Thanks for the input.
My 240 vBgarage
Old 07-15-2003, 05:36 AM   #8
Tubed4evr
Yea when mine was leaking there was oil all over the place that had been slung around by the pulley. It can get pretty messy.
Ryan
Old 07-15-2003, 07:43 PM   #9
kandyflip445
Well then maybe that's it! What is the easiest way you know of checking the main seal itself? Aside from washing out the engine bay.
My 240 vBgarage
Old 07-19-2003, 08:32 AM   #10
Bill Roberts
I brought this back up because I am curious, did you find your oil leak? Were you able to repair it?
Old 07-19-2003, 09:02 PM   #11
kandyflip445
I haven't found it yet. I need to get my funds replenished...(I was on vacation from work for the last 2 weeks). Once I get the money then I'll look into it and I'll fix it.
My 240 vBgarage
Old 07-20-2003, 12:12 AM   #12
mistaanime
mistaanime's Avatar
mistaanime is making a name for him/her selfmistaanime is making a name for him/her self
Send a message via AIM to mistaanime
shiet..I dunno wassup wit mah car..i juss picked up..
I juss changed mah oil today..
I took a ride on mah car.
mean while as i parked the car in the garage..and decided to look under the car.
I found some drop of oil I think..underneth.
the dropp seems like it came from between the engine and mah transmission..anyone know wassup? maybe a seal or something thats fuked up?
-Cherry Red 91 Silfourty-
mistaanime is offline   Reply With Quote
