Old 07-18-2003, 08:45 PM   #1
Flybert
Not picking up radio stations on stereo
I pulled out the head unit that came with my car and when i put it back in, the FM radio didn't work. It only picks up a couple of channels, basically all fuzz. I then installed my new head unit and I have the same problem. I grounded the head unit to a good location. What should I check? It's a 93' S13 coupe. Thanks in advance.
Old 07-18-2003, 09:51 PM   #2
s13driver
s13driver is an unknown quantity at this point
just curious, have you attach the antenna to your old or new unit when you are testing it ?
s13driver is offline   Reply With Quote
Old 07-18-2003, 10:01 PM   #3
Flybert
i hooked up the blue antenna wire from my head unit to my antenna wire on my 240. I don't remember the color though. It didn't work with either head units. It worked before on the old one before I had pulled it out. I put the old one back in and it didn't work.
Old 07-18-2003, 10:07 PM   #4
doainwpg
doainwpg is an unknown quantity at this point
that blue antena wire is just used to make the power antena go up & down. you need to connect the actuall antena, i'm not sure what the stock conector is like on the 240 since mine came with a hacked antenna cable but that has to be hooked up or you'll get nothing
Life's the race everyone's dying to win
Free Ipods Here
doainwpg is offline   Reply With Quote
Old 07-18-2003, 10:44 PM   #5
kandyflip445
kandyflip445's Avatar
The blue wire coming out of the reciever is the wire for a power antenna. It just tells it when to go up and down. The antenna wire that carries the signal is a kinda thick black wire that whould have 2 prongs sticking out. For most recievers(everyone I've seen) you need an antenna adaptor. Only a couple of bux and you can pick it up at Wal-Mart. Plug the antenna signal wire into the adaptor and then take the other end and stick it into the reciever. The plug on the reciever might be built into the unit or it may be hanging out, depending on the brand and model.
My 240 vBgarage
Old 07-19-2003, 11:35 AM   #6
thx247
thx247 is an unknown quantity at this point
its the biggest thick black wire back there, cant miss it.
thx247 is offline   Reply With Quote
Old 07-20-2003, 01:51 AM   #7
popey
popey is an unknown quantity at this point
You might(probably) also need an adapter to attach the antenna cable to your new headunit. You can pick one up from any walmart store. Thats weird, my headunit wouldn't turn on without the correct antenna wire plugged in.
popey is offline   Reply With Quote
Old 07-20-2003, 02:54 AM   #8
kandyflip445
Learn to read, popey.
My 240 vBgarage
Old 07-20-2003, 04:05 AM   #9
Flybert
Thanks. I'll check that wire. Looks like i'll be taking a trip to the electronics store.
