Old 06-20-2010, 12:28 AM   #1
mrbells
mrbells's Avatar
mrbells is an unknown quantity at this point
AVCR/SAFC sensor checks different
So i was working on getting my throttle position % the same on the AVCR and SAFC. I got them both at 100% with the tps voltage from throttle body at .49. It is recommended .45 to .50 with closed throttle. The problem i am having is my avcr and safc read different throttle voltage. My Avcr reads .356 and Safc reads .36/.37 Now that should be the same as my TPS reading correct!?
I do not have my AVCR/SAFC grounds ran together however, the power wires are connected together to the ecu. The throttle wire are the same for the avcr and safc but i separated the two wires when connecting to the throttle wire to ecu.
Any suggestions? Thanks
mrbells is offline   Reply With Quote
Old 06-26-2010, 06:53 AM   #2
jspec240
jspec240's Avatar
jspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfection
If you have seperate grounds thats what could be causing it. either put the grounds together or make sure the ground surfaces are metal to metal even if you have to sand em down.
DREW
SLIDE TO SIDE WORLD WIDE
Feedback!! http://www.zilvia.net/f/showthread.php?t=182673
661 sliders Gymkhana @ buttonwillow
http://zilvia.net/f/south-western-st...-sessions.html
>> Bakersfield Hook up thread <<
jspec240 is offline   Reply With Quote
