Old 06-26-2010, 01:25 AM   #1
K_style
K_style's Avatar
Trader Rating: (63)
Feedback Score: 63 reviews
SR Strong Fuel smell after using 92 octane
I moved up to OR and thankfully 92 octane is standard premium fuel here..
but then I started smell strong un-burnt fuel smell while driving.... not all the time though
does anybody had this kind of experience?
FYI I have S14 SR20DET 550cc GT2860 3" cat-back with aftermarket Cat etc...
and tuned with Power FC by Frank @ Garage BOSO
Old 06-26-2010, 02:10 AM   #2
90white240
90white240's Avatar
90white240 is an unknown quantity at this point
This happened to me to, but turned out to be a fuel leak from the filter.
90white240 is offline   Reply With Quote
Old 06-26-2010, 02:45 AM   #3
K_style
K_style's Avatar
Trader Rating: (63)
I have checked everywhere... but no sign on leak...
Old 06-26-2010, 06:29 AM   #4
jspec240
jspec240's Avatar
jspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfection
check your fuel lines from the rear to the front. Have a friend turn the key on to the acc position (when your fuel pump primes the injectors) get under the car, look and smell around the fuel lines comming from the pass side behind the pass rear tire going to your eng bay. then if there is no rotted lines just double check and tighten all of the clamps should solve your problem.
DREW
SLIDE TO SIDE WORLD WIDE
Feedback!! http://www.zilvia.net/f/showthread.php?t=182673
661 sliders Gymkhana @ buttonwillow
http://zilvia.net/f/south-western-st...-sessions.html
>> Bakersfield Hook up thread <<
jspec240 is offline   Reply With Quote
Old 06-26-2010, 01:54 PM   #5
!Zar!
!Zar!'s Avatar
Check the fuel tank gasket. Or the fuel lines. I've had both go bad a in a few different S13's.
Old 06-28-2010, 12:46 AM   #6
K_style
K_style's Avatar
Trader Rating: (63)
believe it or not... vacuum line by boost controller was ripped.. and after replacing that
it stopped making fuel smell..
Problem solved !! thanks guys
Old 06-28-2010, 12:51 AM   #7
S13 curtis
S13 curtis's Avatar
S13 curtis is an unknown quantity at this point
Lolz man..
S13 curtis is offline   Reply With Quote
Old 06-30-2010, 08:00 PM   #8
greenzenki86
greenzenki86's Avatar
greenzenki86 is an unknown quantity at this point
Woooooooow, thats a new one to me....lol glad its taken care of
Who cares if you have 800hp......
greenzenki86 is offline   Reply With Quote
