Old 07-23-2010, 11:07 AM   #1
koukie180
koukie180 is an unknown quantity at this point
Send a message via AIM to koukie180
MSD Injectors 96 lbs/hr with Connectors & Resistors
For sale are 4x MSD 96 lbs/hr (or about 1008 cc/min) top-feed injectors. These are Peak/Hold at 4A/1A. They will come with clip-less quick-disconnect Bosch EV1 connectors (no more annoying clips) and 6.8 Ohms resistors wired inline. However one resistor has a broken terminal and may need to be replaced or you can try to solder it back. These injectors have less than 10k miles on it. There are no problems at all.
Works great with JWT Fuel Rail and they even come with the retainer clips for proper installation. This is basically all you need to run with JWT Fuel Rail besides new fuel injection hoses etc.
Can be used with regular ECU + Rom tune. This is what I have been using with great results. Works best with standalone management systems that can support Peak/Hold injectors.
4 Injectors, 4 Connectors, 4 Resistors, Retainer Clips, and O-Rings.
For 4 new O-Rings, add $8
PRICE: $210 SHIPPED
koukie180 is offline   Reply With Quote
