![]() Join Date: Sep 2002
![]() Well guys its coming down to the end of my project and since I dont have a FSM yet, I was wondering if someone could spare 10 minutes and lookup some torque specs for me. I would greatly appreacaite it, and whoever comes through, if theres anything I can do for you please let me know. Im a network admin, so I can fix your computer or something.
![]() Front Suspension: Pretty much everything, but Ill list it .... 1)Nut that screws ontot he spindle to hold the hub on 2)Two bolts that hold the strut to the spindle 3)Nut the holds the outer tie rod onto the spindle 4)Nut for the lower ball joint, holds the LCA to the spindle 5)Bolt that mounts the LCA to the car 6)Bolt that mounts the Tension Rod to the car 7)Two nuts the hold the Tension Rod to the LCA 8)Nuts that holds the swaybar to the LCA 9)Three nuts on top of the strut that hold it in place Rear Suspension: Again pretty much everything, but Ill list it .... 10)Nut that screws onto the end of the halfshaft to hold the hub on 11)Nut the screws on the lower ball joint to hold it to the spindle 12)Two bolts the mount the LCA to the car 13)Bolt that holds the UCA to the spindle 14)Bolt that holds the UCA to the car 15)Bolt that holds the upper front toe link to the spindle (the shorter link) 16)Bolt that holds the upper front toe link to the car 17)Bolt that holds the rear upper toe link to the spindle(the longer link) 18)Bolt that holds the rear upper toe link to the car 19)Two nuts on top of the strut that hold it to the car 20)Nut that holds the strut to the spindle Odd Ball Ones: 21)Lug nuts 22)The two nuts the hold the master cylinder to the brake booster Again thanks to whoever takes the time to do this for me, I really appreacaite it. Also you would not only be doing me a favor, but the whole forum, as everyone would be able to search for these later and find out what they are. ![]() |
