Old 12-21-2010, 02:48 PM   #1
SoloSilvia
SoloSilvia's Avatar
Trader Rating: (36)
SoloSilvia has much to be proud ofSoloSilvia has much to be proud ofSoloSilvia has much to be proud ofSoloSilvia has much to be proud ofSoloSilvia has much to be proud ofSoloSilvia has much to be proud ofSoloSilvia has much to be proud ofSoloSilvia has much to be proud ofSoloSilvia has much to be proud ofSoloSilvia has much to be proud ofSoloSilvia has much to be proud of
Feedback Score: 36 reviews
s14 S14 Part out, Black interior, full trunk trim, ect, Barn Lot....
Ok as I was picking some parts out I sold and noticed alot of good items, and some items you members have asked about and I said I didnt have, but seen today I do!
I just parted out an auto 95 240 black interior, well stripped and been selling, I will rattle off a list of parts I have, please keep in mind I have alot more items I need to take inventory of. I just moved houses and everything at the house is in totes, anyways....Stuff in Shop....
All parts are from S14 unless otherwise noted! All parts below are black, although I have most items in blue also if interested. Lots of doubles! Will be adding ....
Dash - $100(has 3 small spots/pokes. upclose pics available upon request, not visible really unless you point them out!)
Passenger Door Panel black/grey insert - $20
Passenger Window switch & surround - $30 (NOT CRACKED)
Driver window Glass - $25
A/C-Heater Control - $25
Rear Seats Grey - $30 set (bottoms stained up, could be cleaned im sure, NO RIPS BURNS!)
Rear Seats SE Patterned Style - $75 set (CLEAN!!!)
Cluster Trim - $15
Door sills - $20
A-Pillars w/speaker pods - $30
Rear 1/4 top panels - $40
Rear 1/4 bottom panels - $50
Rear trim pc w/clips! sits ontop of trunk latch - $20
Behind Rear seat trim(3pc) & molding -$15
OEM radio w/brackets dual unit tape is stuck - $20
OEM Amplifier under rear deck - $30
Complete Airbag System - $100 (this includes L & R airbags with computer and all harness!)
Front Seats Grey - $150 (No rips/burns!)
Misc Rubber Seals, door jams, trunk, ect. - $5-$10 depending which seal
Rear Windshield trim pc(screws at bottom of rear glass)- $20
Map Light(front one w/sunroof) - $15
Rear headliner light - $10
Rear seat Belts - $40
Front Seat Belts - $80
Glove Box - $25
Glove box metal Trim mount - $5
Underdash trim pc, under steering colunm - $15
Kick Panels - $20
Auto Shifters assemblies - $20
Rear View Mirror - $10 (one tiny 1/4" crack top right corner, not chipped!)
Dash vents, side, top corners, inside tubes, ect - $5 each
Visors - black dyed - $15
Sunroof motor - $20
Hood Latch Cable - $20
Rear Struts - $20 (good oems)
All 3 Underdash Boxes:
-Heater Core - $50
-AC Core - $50
-Blower Motor - $50
Metal Dash Bar - $20
Brake Master Cylinder w/Booster - $50
A/C Lines and misc peices - $5 and up
A/C Compressors - $25
Wiper Motor - $20
ABS unit - $50
Cowl Panel - $20
E-Brake Cables - $40
Passenger Rear Brake Caliper - $40
Front Brake Calipers - $30 ea.
Chassis Underdash harness - $75
Misc Chassis harnesses, yanked them all, PM request and offer!
Air Boxes, Air Intake tubes, all oem, couplers, ect...-$5 (&up depending what ya want)
MAFS - $25
Distributer - $40
Starter - $40
Fuel Rail with Injectors - $40 (no FPR)
Engine Mount Brackets -$40
Fan Shroud w/2 sides/bottom/complete - $30
Electric Fan - $30
Clutch Fans - $15
Zenki Tailights - $50
Passenger Fender Maroon - $30
Sunroof Glass - $100 (Glass only w/good seal)
Battery Tray Plastic - $5
Tanabe Subframe Bushings - $80
Ton of KA Engine parts/accessories also!
Ton of SR S13 Engine Misc...
S13 Door Sills black - $20
S13 Driver Kick Panel black - $10
As said before, I have 10 times this stuff, this was all in a spot at my shop I need to do something with asap! lol
PM me with any further requests and offers, everything above is OBO!!!
I can text pics upon request or PM them to you. I know pics make te sale add. I will try and just get some put up here soon, for now, I will take upon request, everything is in good shape unless otherwise noted!
Hatas Keep Hatin, I Keep Rollin!
Last edited by SoloSilvia; 01-18-2011 at 06:50 PM.. Reason: adding parts/selling parts...
SoloSilvia is offline   Reply With Quote
