Old 05-03-2016, 11:20 AM   #1
AllThingsGravy
AllThingsGravy's Avatar
AllThingsGravy is making a name for him/her selfAllThingsGravy is making a name for him/her selfAllThingsGravy is making a name for him/her self
Sr20 Headache
I posted this on the small questions thread and got nothing really but here I go.
Last week: So I was having problems with my starter and I was cranking my car over because the starter wouldn't stop making the noise. While doing that smoke came out from my steering column.
Fast forward to today: I got a replacement starter hooked it all up and double checked everything and when I went to turn the car over not even a crank. I was confused I started triple checking and couldn't figured it out until I remembered the smoke. I took apart the steering column plastic to see the ignition. I found that the black and yellow wire wasn't connect which is the ignition 2. I tried soldering it back on and started it but burned right back off. I took a multimeter and it read 12v for both wire and ignition cylinder on and off. No idea where to go from here. I double checked the grounds and even changed the starter.
AllThingsGravy is offline   Reply With Quote
