Old 12-30-2010, 08:44 AM   #1
YamatoGarage
YamatoGarage's Avatar
YamatoGarage is an unknown quantity at this point
Exclamation clean well bilt rb25det s13 coupe 440whp rb25 w/22,000 original miles !!!
we have well over 20,000 in this car and we are selling it cheap, please pm me if you have any questions
11,500 obo
here are the specs:
here is one pic more pics and info can be found on our website www.yamatogarage.com
car as it sits now
only just over 21,000 original miles on this rb25
heres a video from the dyno before we did the silvia front and paint.
396 whp on 17lbs, car has made 440 whp on 21 lbs just for shits and gigs
YouTube - rb25det , Yamato Garage , donovan gutshall
series 2 rb25det 1997 32,000 km
-----6500 for running 32,000 km r33 gts-t from japan
-----1500 for shared shipping and importation fees
jgy customs mounts ----- 350.00 (not their off the shelf mount kit)
jgy customs ss driveshaft ---- 450.00
apexi power fc / commander ---1,000.00 (rb25 to us conversion from apexi)
greddy intake manifold ---900.00
tomei cams step 1 --- 950.00 (hook up price)
q45 tb ---150.00
greddy timing belt ----100.00
deatchwerks 650cc injectors ----550.00
q45 mass airflow meter ----100.00
walboro 255 fuel pump --- 80.00
z32 fuel filter ----20.00
hybrid gt3076r/tr44 hf turbo (internal gate) .63 ----1,400.00
3 inch ss downpipe ( andy siehausen custom) ----250.00
yamato garage 80mm exhuast no muffler no resonater ---650.00
no cat
nismo thermostat ----90.00
custom 2.5 inch ss intercooler piping ----450.00
gredy rspl front mount intercooler ----750.00
hks ssq bov ----225.00
koyo radiator -----490.00
2x 16 inch fan with auto temp controller -----150.00
garage-D coolant tank ------129.00
5500 psi power steering line ------90.00
garage-D manual boost controller set to 17psi -----120.00
CHASSIS/ SUSPENSION
seam welded chassis
rhino lined under side
no ac,compressor,heater core,lines,window wiper arms,motors.........
gutted firewall jute
gutted sound insulation
gutted wires everywhere not used
power nothing (except moonroof)
megan street coilovers ------900.00
YamatoGarage front underbrace ------89.00
tein tie rods/ends ------135.00
poly steering rack bushings ------70.00
solid aluminum steering shaft spacer ------- 50.00
Yamato Garage tension rods ------170.00
YamatoGarage rear upper control arms -------180.00
Yamato Garage rear toe rods ---------165.00
YamatoGarage rear traction arms --------150.00
poly subframe spacers ---------75.00
YamatoGarage tension rod braces (yashio style) -------129.00
BRAKES:
r32 30mm aluminum calipers -------350.00
Garage-D 5 lug hubs F/R -------650.00
brembo drilled/slotted rotors ---------300.00
axis pbr metal master pads --------79.00 front
ss conversion lines ---------129.00
axis pbr metal master pads (rear) ---------59.00
rear caliper sea horses --------130.00
new oem rear calipers ---------149.00
new oem rear s14 rotors --------200.00
WHEELS:
Enkei RPF-1 -------1,500.00
5x114.3
17x10 18mm
17x10 18mm
235-40-17 goodyear eagle f1 gt. ------290.00 each ( 1,160.00 )
235-40-17 good year eagle f1 gt.
INTERIOR:
apexi rev speed meter -----250.00
autometer phantom boost guage 60mm 0-20 psi -----45.00
stewart warner oil pressure guage -----89.00
stewart warner temp guage -----89.00
stewart warner volts guage -----79.00
custom ls automotive 180 mph speedo wired for rb25 ---- 120.00
infiniti J30 tach swap ----50.00
s14 seats ----200.00
r32 gtr wheel ------100.00
EXTERIOR:
vis carbon fiber oem silvia hood ---------650.00
( custom 1 peice design no seperate under bracing) rare
carbon fiber side pillars
s13 silvia front conversion -----------750.00 ( rare brick headlights )
s13 gtr grille (frp) ------------100.00
oem front lip spoiler -----------100.00
new front window ---------------350.00
new oem inner andouter front window mouldings ---------220.00
new oem inner and outer rear window mouldings -------260.00
new glass everywhere but sunroof , coming soon
new oem turn signals ---------160.00
bodywork 90% done
probly more stuff but i dont remember
the total comes out to 19,875.00 and that is not including the 8,000.00 for the engine swap ! sure you could source a rb25det engine set for 2,500.00 but your not going to get the low mileage not even broke in engine that i got by doing it the right way.
you also have to remember that these prices are not inclyding shipping as well as all the time that went into this car to get it done correctly and to have it tunned to perfection wich was another 1,200.00
YamatoGarage is offline
