Old 01-30-2011, 08:32 PM   #1
nissan240sxkid
nissan240sxkid will become famous soon enoughnissan240sxkid will become famous soon enoughnissan240sxkid will become famous soon enoughnissan240sxkid will become famous soon enough
Exclamation ‘92 Nissan 240sx Coupe S13 Silvia & TONS of PARTS FOR SALE!!
Make/Model/Trim: Nissan 240sx Coupe
Year: 1992
VIN: JN1M34P0NW106234
Mileage: 180000 (Chassis Only)
Engine Type: S13 SR20DET Blacktop
Transmission Type: 5-Speed Manual
Options: Power locks, Power windows, Power steering, Power Sun-Roof
Modifications: See Lists Below
Any Included Parts, if applicable: See Lists Below
Flaws (mechanical and otherwise stated in order of importance): See Description Below
*** ‘92 Nissan 240sx Coupe S13 Silvia & TONS of PARTS FOR SALE ***
I was driving when someone decided to change lanes into me and damaged the front passenger fender, hood, passenger headlight, tie rod, and now both drivers side rims have curb rash. The car still runs great and will drive perfect once the tie rod is replaced. There’s no frame damage, as you can see from the photos. I understand that all I need is a few hundred bucks to fix it and it would be fine, but the truth is, I was thinking about selling the car before this accident. I have had this car for about 5 years and have been slowly building it as a side project, but I’ve gotten multiple tickets and now with the accident I’ve just lost interest in it all together.
Most of these parts are barely used with less than 3000 miles on them, since this car was only occasionally driven and had sat for about 3 years in storage with no motor. The car currently makes 420rwhp on pump gas at low boost (19-20psi). If you want to run race gas and turn up the boost, all of the parts and the fuel system are in the car and able to handle more power. The car is very fast and with a more appropriate drag radial on the car it will suit the drag strip well, but it still spools fast enough to drift. It handles very well on the street and the HKS Hi-power exhaust is surprisingly quiet.
I’m not an amateur car enthusiast and I know my way around the 240sx. I’m a professional mechanic, and although it may not look like a showroom car as it sits now, it is mechanically sound. I was working on getting it painted and putting all of my finishing touches on it, including lap belts, and a radio. I have a lot of spare parts and miscellaneous items to sell, including other engines, transmissions, etc. I’d like to sell everything that I have that is Nissan and 240sx related, including the car as a whole running vehicle.
The following list is for the car as a whole running car with all of the parts it includes, and another list is for all of the other miscellaneous parts that I would like to also sell. If someone would like to make me an offer to take everything, I would consider it. If the car doesn’t sell, I will end up parting it out. I might have invested over $40,000 between chassis’s, motors, parts that I’ve had and sold in the past, etc. I understand I won’t get anywhere near that back, but the car and all of the parts are still worth good money.
PM me or email me and send payments to my PayPal at [email protected][/SIZE]
Shipping parts and/or the whole car will be the responsibility of the buyer.
1992 Nissan 240sx Coupe S13 Silvia includes the following:
ENGINE & DRIVETRAIN
SR20DET Blacktop
Wiseco Pistons
ACL Bearings 1800
ARP Head studs
HKS Head gasket
GReddy Pulley Kit-200
ATi Engine Dampener-300
ATS Triple Carbon Clutch-sold
Custom Twin Scroll T4 Manifold-400
GT3582R w/ Twin Scroll back housing-100 for housing turbo is sold
(2) TiAL 44mm Wastegates-sold
Custom Dump tubes & Downpipe-make offer with manifold
ALL Turbo lines are Stainless Steel Braided & have AN fittings-sold
Turbo blanket-sold
4” Intake w/ AEM Filter
“Mr. Gasket” Exhaust Manifold Gasket-why am I even trying to sell this
HKS Hi-Power CAT-back Exhaust-250
GReddy Intake Manifold-500
70mm Pulsar Throttle body (water fittings and other idle things machined off)-500
SARD Fuel Rail-sold
Precision 1000cc Injectors-sold
SARD Fuel Pressure Regulator-200
Aeromotive Fuel Filter-sold
-8AN Stainless Steel Braided Fuel Feed line & fittings-sold
-6AN Stainless Steel Braided Fuel Return line & fittings-sold
BOSCH 044 Fuel Pump (externally mounted w/ bulkhead under fuel tank)-sold pump
GReddy Oil Cooler (mounted but never plumbed up or used)-500
Nismo Motor mounts & Tranny mount-150
Splitfire Coil Packs-350
TiAL Purple 50mm Blow-off Valve-200
GReddy Type-R Intercooler (1 pipe modified to fit top mount but have pipe for stock intake mani)-450
GReddy Upper Intercooler pipe (modified for TiAL BOV)-75
Power Enterprise Belts-dont buy used belts unless u realy want them
Wire tuck w/ rear mounted battery & no fuse boxes in engine bay (only 90% complete – everything works but final tuck in cabin needs to be done)-head aches
Samco hoses – Upper and lower (Black)-100
Koyo Radiator-200
Flex-a-lite Fans (controlled by ECU, one fan has 2 broken blades but it works and is balanced)-100
HKS F-con V-Pro 3.4 (Newest version with harness and sensors)-1800
B&M Short Shifter-sold
“Drive Shaft Shop” Aluminum 1 piece Drive Shaft-350
Nismo Slave Cylinder-120
Agency Power Stainless Steel Braided Clutch line-30
New Master Cylinders for Brakes and Clutch-go to napa
Nismo Pro 2-Way Rear Differential-900
Brake Master Cylinder Heat Shield-sold
Blitz Radiator Cap-b/o
JAZ Radiator Overflow Bottle-sold
Hallman Manual Boost Controller-might keep this one the one in the evo is scratched
CHASSIS & SUSPENSION
S13 Silvia Front End (or what’s left of it)-b/o
HID Headlights-b/o
Tanabe Sustec Pro-DD Coilovers-750
Upgraded Tension Rods-100
TEIN Inner & Outer Tie Rods-why r these on here one side is broken
Battle Version Control Arms-200
JIC Toe Arms-100
Kazama Control Links-100
Brembo Rear Rotors-50
Wilwood Front Upgraded Big Brake Kit (Slotted 2-pc Rotors)-600
Peak Performance 5-Lug Front & Rear Hubs (Front has their nicer kit with extended studs, made of Chromoly)-650
5-Zigen 17” Rims (Fronts: 17x9+15, Rears: 17x10+12-500 with tires
Cooper Tires (Plenty of life left)-go with rims
Wangan Rear Spoiler (stock spoiler too)-100
Rolled Rear Quarters-u get these if you buy the shell
INTERIOR
Key!s Suede Steering Wheel-250
Momo Wheel Hub-50
Sparco Quick Release (w/ a machined adapter plate to work together with hub and wheel)-250
Yashio Factory Shift Knob & Shift Boot-b/o I might keep this for other car
BRIDE Upholstered Rear Seat-750
BRIDE Upholstered Glove Box-500
Stock 240sx Leather Front Seats-50
Brand New Black Carpet (not installed with trunk)-200
Omori 60mm Boost Gauge-50
AEM 52mm Wideband-b/o or might keep as spare
Heads-up Display Speedometer-b/o
ALL OTHER NISSAN & 240sx RELATED PARTS (not included with the car):
ENGINES & DRIVETRAINS
S13 SR20DET Redtop Head-100
S13 SR20DET Blacktop Head-100
Built S13 SR20DET Blacktop Head (worked on by Head Games & Mazworx w/ machined quench areas, Manley 1mm over stainless steel valves, Tomei solid lifters, Tomei Rocker Arm Stoppers, Tomei Cam Gears, SuperTech Dual Valve Springs, Titanium Retainers, drilled out for ½” Head studs)
S13 SR20DET Blacktop Block (w/ Darton Sleeves pressed in & machined to 87mm, CP Pistons 87mm-Brand New in Box, Manley TurboTuff Rods, ARP ½” Head Studs, ARP Main studs, New Water pump, New Oil pump, New Timing chain & New guides, New Gaskets)
Kelford 274/278 Int./Exh. Cams (Brand New in Box)
S13 SR20DET Valve cover, Shaved, -10AN fittings for breathers
Yashio Factory Water Pump Pulley (Brand New in Box)-120
GReddy Chrome Oil Cap-50
OSGiken 3-speed Set – New in Box-1500
OSGiken Input Shaft-goes with gear kit
S14 Manual 5-speed Transmission-250
S13 SR20DET 2.0L Crank- might use it to put this other crazy motor together and sell it as a whole
ARC Gradient Plug Cover for S13 SR20DET-b/o
S13 SR20DET Transmission (disassembled)-b/o
INTERIOR & EXTERIOR
S13 240sx Dash-friend has a 240 that needs a dash
JDM Gauge Cluster w/ 9000rpm Tachometer(the clear cover part isnt mint, I gues u need that head light restore stuff-60
Key!s Suede Shift Knob (matches Key!s wheel in car)-who ever buys the wheel please buy this
MISCELLANEOUS
S13 SR20DET Stock Intake Manifolds (4 or 5 available)-b/o
Stock S13 Driveshaft-b/o
Battle Version (or replica) Front Lower Control Arms for S13-b/o
DIF Dual Fan Controller-50
Yashio Factory Radiator Cooling Panel-200
A few Starters-b/o
A few Alternators-b/o
Several Brackets-ask
Loads of Nuts & Bolts-really
Plugs, Wiring, Etc.
Z32 MAF Pigtail-30
S13 A/C Condenser-b/o
KA24DE A/C Compressor-b/o
SR20DET A/C Compressor-b/o
Stock Flywheel-what its worth in scrap
Bell Housing Plates-b/o
Fuse Box Covers-they're not mint anymore but if you dont have one
Radiator Overflow Bottle stock-b/o
GReddy E-Manage Ultimate Harness-this ecu sucked dont buy this
Stock Glove Box-b/o
Stock Suspension Arms-b/o
Goodridge Rear Stainless Steel Braided Brake Lines – New in Box-b/o
Pair of 5-Bolt Axles-b/o
Brass Bushings for Door Hinges – New in Box-40
Shift Boot Ring-b/o
Stock Shift Knob-sold
Stock Shift Boot-20
Megan Sub-frame Bushings – Never installed-b/o
GReddy Downpipe (cut in half but I can TIG it back together)b/o
nissan240sxkid is offline
Old 01-30-2011, 08:44 PM   #2
Mooch
Mooch is an unknown quantity at this point
I'm interested in your coilovers. Shoot me a PM with a price shipped. I need some yesterday.
Mooch is offline
Old 01-30-2011, 08:51 PM   #3
ze12o
ze12o's Avatar
Trader Rating: (26)
ze12o is an unknown quantity at this point
Feedback Score: 26 reviews
damn sounded like a nice car. are you parting or are you trying to sell the car as a whole?
ಠ_ಠ
ze12o is offline
Old 01-30-2011, 08:52 PM   #4
MGriff240
MGriff240 is an unknown quantity at this point
Send a message via MSN to MGriff240
Email sent asking about some interior pieces.
MGriff240 is offline
Old 01-30-2011, 08:59 PM   #5
nissan240sxkid
I would rather sell the car as a whole... but if it doesn't sell then I will part it out.
Old 01-30-2011, 09:22 PM   #6
ze12o
ze12o's Avatar
Trader Rating: (26)
If you decide to part interested in all of these parts depending on price. I always head to jersey so we can talk in person.
Blitz Radiator Cap
JIC Toe Arms
Kelford 274/278 Int./Exh. Cams (Brand New in Box) <-are these for ka or sr?
ಠ_ಠ
ze12o is offline
Old 01-30-2011, 09:30 PM   #7
bp-mx3
bp-mx3 is an unknown quantity at this point
How much meat on the rear rotors if your selling them? Also do you have j30 diff. solid bushings?
bp-mx3 is offline
Old 01-30-2011, 09:32 PM   #8
wh0aitznic0
wh0aitznic0's Avatar
wh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enough
How much do you want for the FN's? I'm local in NJ. No tires.
SPLparts.com * PoweredByMax.net
Originally Posted by hailandkill View Post
wh0aitznic0 -- has or had a shocker sticker on his car at one point, is asian with a gooey white center
<3
Nothing says, 'I'm broke and still trying', like aftermarket steelies.
wh0aitznic0 is offline
Old 01-30-2011, 10:20 PM   #9
nissan240sxkid
I'm trying to sell them with the car, so if the car doesn't sell, I will part them out. They have about 99% life left on them.
I'm trying to sell the rims with the car, but if the car doesn't sell, I will sell the rims, but I don't think I'll seperate the tires. If you want, since you're local, you can come by and see the wheels. Let me know.
Old 01-30-2011, 10:58 PM   #10
udon!
udon! is an unknown quantity at this point
Can I get pics of the black carpet?
udon! is offline
Old 01-30-2011, 11:45 PM   #11
negrosx13
negrosx13's Avatar
negrosx13 is an unknown quantity at this point
Send a message via AIM to negrosx13
The hks exhaust,New Master Cylinders for Brakes and Clutch, Hallman Manual Boost Controller,pm me a price..also im interested in a lot of other parts as well..
MORE BACON STRIPS
negrosx13 is offline
Old 01-31-2011, 12:45 AM   #12
510det
510det is an unknown quantity at this point
interested in the Radiator overflow bottle. How much?
510det is offline
Old 01-31-2011, 05:48 AM   #13
SilviaSliderNj
SilviaSliderNj's Avatar
Trader Rating: (22)
SilviaSliderNj is an unknown quantity at this point
Feedback Score: 22 reviews
bump for no price,no engine shots,no dyno proveing numbers.....????
SilviaSliderNj is offline
Old 01-31-2011, 07:43 AM   #14
emericanz
emericanz's Avatar
emericanz is an unknown quantity at this point
Momo Wheel Hub
and your power steering rez with lines
thats all pm me
emericanz is offline
Old 01-31-2011, 07:52 AM   #15
nissan240sxkid
More pics are coming...I will post and reply when I get home from work, so I cant responned untill night time.
Old 01-31-2011, 11:30 AM   #16
mugenworks247
mugenworks247 is an unknown quantity at this point
arc gradient cover shipped to 17701?
mugenworks247 is offline
Old 01-31-2011, 11:38 AM   #17
jbuttons123
jbuttons123 is an unknown quantity at this point
still have z32 maf?
jbuttons123 is offline
Old 01-31-2011, 12:00 PM   #18
noname7198
noname7198's Avatar
noname7198 is a splendid one to beholdnoname7198 is a splendid one to beholdnoname7198 is a splendid one to beholdnoname7198 is a splendid one to beholdnoname7198 is a splendid one to beholdnoname7198 is a splendid one to beholdnoname7198 is a splendid one to beholdnoname7198 is a splendid one to beholdnoname7198 is a splendid one to beholdnoname7198 is a splendid one to beholdnoname7198 is a splendid one to behold
I'll pick up the rear wheels if/when you decide to part out.
noname7198 is offline
Old 01-31-2011, 01:40 PM   #19
blueshark123
blueshark123's Avatar
Trader Rating: (55)
Feedback Score: 55 reviews
if youre selling as whole then put it in the right section
blueshark123 is offline
Old 01-31-2011, 02:24 PM   #20
Rockogtr
Rockogtr is a jewel in the roughRockogtr is a jewel in the roughRockogtr is a jewel in the roughRockogtr is a jewel in the roughRockogtr is a jewel in the roughRockogtr is a jewel in the roughRockogtr is a jewel in the roughRockogtr is a jewel in the rough
Send a message via AIM to Rockogtr
pm with a price on the cooling pannel and a price shipped to 01453
Rockogtr is offline
Old 01-31-2011, 02:36 PM   #21
Lil_D
Lil_D is an unknown quantity at this point
do you have inlet and outlet for t25 turbo? if so how much shipped to 94583
Lil_D is offline
Old 01-31-2011, 02:47 PM   #22
phaiwezzie
phaiwezzie's Avatar
phaiwezzie has a little shameless behavior in the past
nismo slave? how many miles, pm price
phaiwezzie is offline
Old 01-31-2011, 07:33 PM   #23
nissan240sxkid
I posted a few pics and for every one that has pm'd me please be patient I trying to figure everything out
Old 01-31-2011, 07:50 PM   #24
DriftReddy
DriftReddy is an unknown quantity at this point
Hey dude, PM me a price for the Key!s wheel/shift knob, the cooling panel, and the motor mounts when u get a chance...
DriftReddy is offline
Old 01-31-2011, 09:41 PM   #25
nissan240sxkid
Wold anyone give me more than $13,000 for everything car and extra parts?
Old 02-01-2011, 07:08 AM   #26
hellothere240sx
hellothere240sx is an unknown quantity at this point
pm me a price for intercooler please
hellothere240sx is offline
Old 02-01-2011, 10:09 AM   #27
boosted KA24DE
boosted KA24DE's Avatar
Trader Rating: (22)
boosted KA24DE is an unknown quantity at this point
Are rear seats available?
JDM Fashion isn't always good!
boosted KA24DE is offline
Old 02-01-2011, 11:18 AM   #28
boosted2.0
boosted2.0 is an unknown quantity at this point
parts!!!
HEY U interested in parting with the turbo and all the lines,downpipe ,and wastgate?? Let me know asap i need one very soon !! pm me !!!
boosted2.0 is offline
Old 02-01-2011, 11:44 AM   #29
240Zfunahollic
240Zfunahollic is an unknown quantity at this point
how about $25 for the greddy oil cap?
http://zilvia.net/f/image.php?type=sigpic&userid=15347&dateline=123195  6786
Visit My Trader rating page
http://zilvia.net/f/traderratings.html?u=15347
240Zfunahollic is offline
Old 02-03-2011, 06:54 AM   #30
jersey.drifter
jersey.drifter is an unknown quantity at this point
pm'd!!!!!!!!!!!!!
jersey.drifter is offline
greddy, hks, s13, s14, silvia
