Old 02-03-2011, 08:31 PM   #1
guitaraholic
guitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of light
Top mount manifold question
Does anyone know of a top mount manifold where the collector pair up cylinders 2&3 and 1&4 side by side. Basically the same way a divided/twin scroll manifold is set up, but without the twin scroll?
guitaraholic is offline   Reply With Quote
Old 02-03-2011, 08:57 PM   #2
idahotuner
idahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond repute
Send a message via AIM to idahotuner Send a message via MSN to idahotuner
why would it matter if they all merge together in one collector
idahotuner is offline   Reply With Quote
Old 02-04-2011, 03:56 AM   #3
guitaraholic
because I'll be fabricating a valve that goes inside the collector and blocks off half of a twin scroll. Kind of like the quick spool valve, but I believe it to be a lot more effiecient because it will not cause the turbulance it causes.
When it is set to "open", it will essentually split the manifold in half, pairing two of the pipes together. So far it would wind up pairing 1&2 and 3&4 together, causing double pulses to be put into each "scroll"
Old 02-05-2011, 03:03 AM   #4
godrifttoday
godrifttoday's Avatar
Trader Rating: (82)
godrifttoday is an unknown quantity at this point
Feedback Score: 82 reviews
You need a twin scroll turbo! And twin scroll manifold then it will work
NEED Bolt kits for your car?
http://i48.tinypic.com/6gx5e0.jpg
godrifttoday is offline   Reply With Quote
