Old 09-27-2003, 05:36 AM   #1
s13silady
s13silady's Avatar
s13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfection
guage cluster install...
just put in my SR gauge cluster today... fairly easy... found it easier to drop the steering coloumn completely (held on by 2 bolts)... still in very good condition but had to use the clear cover plate from the ka cluster...other than that its cool... feels funny going about 65 but the numbers read 100.. lol ill get used to it...
next is a digital climate control i got with the plug in harness to the SR..
EDIT: oh yah once i got everything bolted back on my battery took a dump and i had to pushstart it and now its sitting in front of my house not being driven until i get a new battery...
anyone know the difference between the optima redtop and optima yellow top??
s13silady is offline   Reply With Quote
Old 09-27-2003, 09:25 AM   #2
WhiteNissanS13
WhiteNissanS13 is an unknown quantity at this point
Send a message via AIM to WhiteNissanS13 Send a message via Yahoo to WhiteNissanS13
i think
The RED top is more of a starter battery, it creates more cranking amps than the YELLOW top. the YELLOWtop is more of a performance battery. it has a Higher voltage rating, less resistance, larger capacity, and a longer lasting reverve capacity.
REDTOP
These batteries are designed for cyclic applications and for use in vehicles with large
accessory loads.
YELLOWTOP
These batteries are designed for engine starting applications. They are not
recommended or warranted for use in deep cycle applications.
WhiteNissanS13 is offline   Reply With Quote
Old 09-27-2003, 11:06 AM   #3
old_s13
old_s13's Avatar
old_s13 is an unknown quantity at this point
Go to optima's website, the red-top is the standard sealed battery that is designed for almost all automotive applications.
The yellow-top is deep cycle and designed for heavier duty applications where the battery will take some serious use (loose more than its surface charge), and where it will need to be re-charged more often.
The blue-top is a similar deep cycle battery but intended for marine use. I havent looked at the product specs in terms of amps and storing capacity, but it seems like the blue top is just a more performance oriented deep cycle battery than the yellow.
For most automotive folks, a red-top should do the job. I wanted a crazy battery and spent extra on the blue top, plus I wanted the additional power posts since I *had* a lot of accessories at the time.. oh I cant wait to finish my car.. one day.
Anyway, red top for just about everyone.
old_s13 is offline   Reply With Quote
Old 09-27-2003, 03:55 PM   #4
s13silady
s13silady's Avatar
thanks for your replies guys... did my research and am going with the red-top...i only have one sub and one amp with after market speakers... nothing else...
ive heard on FA that the optimas yellow tops causes the AF to run lean anyone ever heard of that?
Old 09-27-2003, 03:58 PM   #5
WhiteNissanS13
Originally posted by WhiteNissanS13
REDTOP
accessory loads.
YELLOWTOP
WHOA whoopsie i messed up i reversed the yellowtop and redtop meanings.
