Old 04-25-2011, 07:29 PM   #1
|BOOST|
|BOOST| is an unknown quantity at this point
FS: RED TOP SR20DET motor set. MOTOR, TURBO, TRANS and MUCH MORE! w/ PICS!
UP FOR SALE!! SR20det REDtop! 6x,xxx mi+ on motor. motor was in a S13.
THE COMPLETE SWAP IS FOR SALE!!!.
What you will buy:
-motor/radiator w/ shroud
-trans/clutch/short shifter
-turbo set up/IC/fuel set up/intake/z32 MAF
-harness
-EVERYTHING YOU NEED to drop this into your car.
DETAILS/MODS
Motor:
-megan mounts
HEAD
-BC retainers/springs/272-272 cams(cams arent installed,BNIB)
-cosworth head gasket
BOTTOM END
-stock
TURBO set up
-borg warner s360
-Compressor wheel - 60.02mm/83.46mm 69lbs/min
Turbine wheel - 76mm/68mm
Compressor inlet - 4" hose Ported Shroud
Compressor outlet - 3" hose
Turbine Inlet - Divided T4 .91 A/R
Turbine Outlet - 3.5" v band
-peakboost ram head exhaust manifold(t3)
-38mm EWG w/ dump tube
-Powered by Max high mount intercooler
-greddy EBC
-z32 MAF
-z32 jim wolf tech pop charger intake
COLD side/fuel set up
-freddy intake manifold w/ custom throttle cable bracket.
-venom 1000cc injectors
-Powered by Max FPR w/ gauge
-all new vacuum lines
TRANS
-SR trans
-6 puck ACT sprung clutch
-short shifter
RADIATOR
-SR20 mishimoto aluminum rad
-clutch fan shroud.
WHAT YOU WILL NEED.
-install cams
-down pipe
-TUNE
-testiculos
.....should be done and beastial after that...
PRICE
-$3k
If you meet my price. ill throw in some stock parts..
PICS:
more pics to come. or you can request them.
call/txt (619)850-662FOUR.
ALL PARTS LOCATED IN SAN DIEGO
|BOOST| is offline
