Old 04-20-2011, 11:54 AM   #1
digitalightkenz
digitalightkenz will become famous soon enoughdigitalightkenz will become famous soon enoughdigitalightkenz will become famous soon enoughdigitalightkenz will become famous soon enough
FS/FT IMPREZA OUTBACK, FULLY STI MOTOR, 400hp SLEEPER!
PLEASE BUMP IF YOU SEE MY THREAD.
1995 Subaru Impreza Outback SLEEPER!
Clean Title, TAGS ARE UP TO DATE!!!!!
100,000 on car
ENGINE: (MOTOR WORK WAS OVER 6,000 dollars)
Motor now has 300 miles, and I just connected the boost, It’s set around 5 psi. I have properly initiated the process to break in the motor. MOTOR SHOULD BE ABLE TO DO 400HP +
It's running on a base map made by John in Outfront MotorSports. Motor still needs to be broken into and then a full tune.
Motor was built and put together by Gino in Apollo Performance. A VERY reputable shop in the Subaru Community.
- JDM EJ20G (imported directly from Japan) Version II STI engine
- New 20G TD06 Turbo .
-New Forged Pistons (stock was not forged)
-Closed Deck Block (stock was not closed deck)
-New Race Bearings
-All New Seals
-New Headgasket
-New Valve Job
-Resurfaced Heads
-New Coil Packs
-New Water Pump
-New Timing Belt
-New Oil Cooler
-HKS SSQV BOV
-ARC Intake (also directly from Japan), PRETTY RARE
-NO CAT, 3 Inch piping all the way back.
ECU:
Linkplus Plug and Play ECU with electronic display unit
DRIVETRAIN: (I've easily spent over 2,500 here)
- 2003 WRX Tranny with 70K
- 2003 WRX Diff 70K
- 2003 WRX Driveshaft
- Brand new slave cylinder fork with new shaft and new bolts
- BRAND NEW ACT CLUTCH
- BRAND NEW ACT FLYWHEEL
- BRAND NEW ACT PRESSURE PLATE
INTERIOR:
- Super clean interior, no rips on seats or dash.
- Innovative wideband
- boost gauge
- Electronic display unit
- JDM NARDI original steering wheel.
SUSPENSION:
- Stock suspension and brakes.
Exterior:
-JDM STI Hood
-JDM STI Front Bumper
-Factory roof rack.
WHAT IT NEEDS:
-Paint job. I started to sand it down already.
-Dash Wiring (the dash is in place but many of the functions are not wired up, the signals and lights all work perfectly fine)
THE CAR HAS NO problems whatsoever! I need to sell it to someone who will finish it and put it into good use. SPANK ALL KINDS OF MUSTANG's, Camaro’s, PORSHE's, VETTs, RX7's, turbo Hondas, while buying groceries and having the kids in the car. And daily drive it! Again, the engine is BRAND New, it is definitely a sleeper and track monster, the parts alone are worth more than 8K
$7,999 TRADES OK, LOWBALLERS ARE NOT WELCOMED! ANY REASONABLE OFFER WILL NOT BE REFUSED.
CONTACT INFO:
1-323-369-7175 CALL/TEXT for immediate response
[email protected]
Feel free to email me if you have any questions, Thank you.
PICS:
Exterior:
INTERIOR:
ECU:
MOTOR:
OPEN DECK
CLOSED DECK
Ken.
digitalightkenz is offline   Reply With Quote
