Old 05-10-2011, 01:21 PM   #1
angzt
angzt's Avatar
angzt is an unknown quantity at this point
SR20DET S13 Blacktop Part's for Sale
I rebuilt an SR so I can put it in my Datsun 510.
Just looking to clear up some space.
The engine was fresh from Japan when I rebuilt it.
I did not test run the engine before part removal.
I cannot guarantee anything!
All the part's I took off have been on shelves in my basement ever since.
Everything you see is how they were when I removed them.
All part's are "AS IS" - "USED". No warranty. No nothing. PM me questions if you have them.
What you see is what you get. If you want brand new I would recommend going to NISSAN. Most of the stuff is still available.
Please make me an offer.
(private message me or respond to this thread)
I have a few more part's to list.
If you need something, ask, I might have it.
Thank You.
Turbo Oil Drain Return
Fuel Rail
Oil Cap + Gasket $10 Shipped??????
Harmonic Balancer / Crank Pulley Bolt + Washer
Harmonic Balancer / Crank Pulley + Water Pump Pulley
Throttle Body Mounting Bolts + Split Lock Washers
Fuel Injector Cap's + Insulators + Hardware
Fuel Injector O-Ring (Top + Bottom)
Valve Cover Hardware
Timing Chain Guides + Slide Bolt
Throttle Position Sensor $40 Shipped??????
Timing Chain
Crank Angle Sensor $50 Shipped??????
Fuel Injectors
Exhaust Manifold $40 Shipped??????
Heat Shields
AC Compressor + Mounting Bracket $75 Shipped??????
Power Steering Pump + Mounting Bracket $100 Shipped??????
GReddy Power Steering Pulley (never unwrapped) + Hardware + Box + Instructions $65 Shipped??????
angzt is offline
