Quick Question - Blocking BOV on S14 Series 2 SR20det
Yes i have tried searching, but there is actually no clear post that i can find.
When blocking the factory BOV, do you only need to block these 3 pipes? Intake, outtake and actuator pipe? |
![]() Join Date: Sep 2005
Why would you block "pipes" not connected to the object you intend to eliminate?
Are you planning to use any of these lines? Are you going to change the cold pipe, and weld on a flange for an aftermarket BOV Are you moving the BOV to the Hotside? If you just want to block of the BPV then yes, block off any open holes in the intake system, even the ones you don't see.
