Old 07-03-2011, 12:46 PM   #1
JDS Performance
JDS Performance's Avatar
Trader Rating: (53)
JDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of light
Feedback Score: 53 reviews
FS: NC: 240sx KA24DE Heads S13 & S14
Concord, NC 28025
[email protected]
__________________________________________________ _________________________________________________
S14 240sx KA24DE Head
///SOLD///
Pulled from a 96' running motor that was pulled for a motor swap and then parted out.
Inside has been cleaned
Also comes with valve cover (no bolts), cams, cam gears, idler gear/bolts
Inside valve cover is very clean, cams are like new condition
Around 120k miles
S13 240sx KA24DE Head
$135.00
Pulled from a 93' running motor that was pulled for burning 1qt of oil a month - will need new valve oil seals - I can do this for an aditional $65.00 (parts included)
Also comes with valve cover (no bolts), front upper timing cover (no bolts) cams, cam gears, idler gear/bolts
///No Exhaust Cam///
Around 180k miles
A little damage on the front 2 cam caps - but does not affect the performance at all (check pix)
$100.00
Pulled from a 91' running motor that needed new rings (low compression)
Also comes with valve cover (no bolts), idler gear/bolts
No front cover, lifter/shims or cams
Has rust but will come clean with a hot tank
Around 190k miles
KA24DE Cams with gears
S14 Intake - $20.00
(2) S13 Intake - $20.00
S13 Exhaust - ///SOLD///
All pix located here:
http://s82.photobucket.com/albums/j274/jos...eads/?start=all
JDS Performance is offline
Old 07-05-2011, 08:55 PM   #2
JDS Performance
Trader Rating: (53)
Parts added
Old 07-06-2011, 07:21 PM   #3
merks
merks's Avatar
merks is an unknown quantity at this point
Bump for a great seller!
90 hatch-first s13- first failed project
96 zenki, hid retro fit- ls1 2013
merks is offline
