Old 08-01-2011, 12:32 AM   #1
Driven08
Trader Rating: (354)
Driven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfection
Feedback Score: 354 reviews
Cool TW:89 240sx hatch,Kouki Aero,Sr20det,Full Suspension,T28,5 lug,PBM,Greddy,etc
Testing Waters Testing Waters Testing Waters Testing Waters
1989 Nissan 240sx Hatch Power Windows,Locks,Mirrors
Cons
-Very Few Dents/Dings
-Salvage Title(Was told for theft back when it was stock years ago)
-Needs Paint
-"Zilvia Starter Package"- Look at my Trader Rating and join date and you'll see I've been around
Engine/Performance:
S13 SR20det Red Top
Only ran Mobil 1Full Synthetic 10w30(just changed (7/30)
Brand New CAS
Brand New TPS
Brand New IACV
Brand New Fan Shroud
Brand New Gates Micro V Belts
Brand New Black Silicone Hoses
Brand New Coolant Overflow Tank
Brand New OEM timing Chain Tensioner
Brand New S14 SR Water pump
Brand New Walbro 255lph Fuel Pump
Brand New Fuel Filter
Greddy 52mm Black Electric Oil Pressure Gauge
Greddy 52mm Black Electric Water Temp Gauge
Greddy 52mm Black Electric Boost Gauge
3 Row CX Racing Radiator
Nismo Thermostat
All New 7 layer S15 Exh. Manifold gaskets and turbo gaskets
Metal Headgasket(unknown brand)
S15 Spec-R Garrett T28
HKS Wastegate Actuator
Earls SS Oil and Coolant lines
ARC BOV
Greddy Intercooler
Nismo 740cc Injectors
N62 Maf
OEM Mazda Miata Battery(1 yr old)
RS-Enthalpy Tuned Ecu(740cc,T28, 14 psi)
Apex'i Filter
Tomei Intake Adapter
Aftermarket Elbow
Megan DP
Catco 3" high flow cat
Blitz JDM 3" Exhaust(cut and welded to sit higher)
14lb Flywheel
6 Puck Clutch
PBM Magnetic drain plug
Circuit Sport short Shifter
Suspension/Brakes:
Brand New PBM Coilovers(probably 600 miles on them)
Nismo 2 way LSD
JDM Diff w/ 5 bolt axels and diff cover
SPL Version 1 Toe Rod's
SPL Version 1 Traction Rod's
Kazama RUCA's
Circuit Sport Tension Rods
Johnny Fraz Tension Rod Brace(Like Nismo Brace)
Tein Inner Tie Rod's
Tein Outer Tie Rod's
Energy Suspension outer tie rod boots
Energy Suspension Front Sway bar bushings/endlinks
Energy Suspension rack & pinion bushings
Front Strut Bar
Z32 Rear 5 Lug Hubs
Aftermarket 5 Lug Front hubs
Z32 30mm Front Calipers w/ss lines
Project Mu Pads(Front)
BRAND NEW SS595 Federal 215/40/17 tires(Maybe 400 miles)
MB Battles(17x9.5 +15 offset) in bright silver
Slip on 10mm spacers front
20mm Custom Adapters in rear)
Exterior:
Kouki OEM Bumper(New)
Kouki OEM Turn Signals(New)
Kouki OEM Position Lights(New)
Kouki OEM Extensions(New)
Kouki OEM Extension Brackets(New)
Kouki OEM Sideskirts
Kouki OEM Valences(missing center )
Kouki FPR OEM Style Spoiler
Kouki FPR OEM Style Lip(Vanquish?)
Kouki OEM Tail lights
Glass H4 Housing Headlights
Slim 6k HID
Interior:
Full Interior
S14 Manuel Seat Belts
Clean Black Dash
Nardi Classic(kind of beat)
Works Bell Hub
Newish Turn Signal and Wiper Stalk
Nismo Shift Knob
New Leather Shift boot
F1 Spec Sidemount Seat
F1 Spec rails
S14 Passenger seat
Pioneer Speakers
Center Gauge Pod w/ Greddy Gauges
DOHC Cluster w/ SR RPM
Price: Reasonable offers! None of that B.S. saying "Oh its salvaged" because the frame is very straight and a CLEAN TITLE doesn't always mean its legit(you don't have to go through insurance or even dmv if you crashed/got hit and someone took off,etc)
Also, I might be looking for a trade so let me know what you have. Equal value please.
Recent Pics:
Driven08 is offline   Reply With Quote
