Old 03-16-2016, 10:54 PM   #1
SLYDEWAYS 96
SLYDEWAYS 96's Avatar
Trader Rating: (34)
SLYDEWAYS 96 is an unknown quantity at this point
Feedback Score: 34 reviews
Raf's 1jz zenki backyard build
Whats up Zilvia, My name is Ashraf, 20 years old & going to school for mechanical engineering and work full time at a diesel truck shop.
Had my first 240 at 16 and crashed into a pole. First car being rwd, no lsd, driving on black ice with no experience, crashed it a few weeks after owning it. After the 240, I had a 07 si to drive around for a year, then switched it up and got a 03 350z which made close to 400whp on a nitrous setup.
Decided I want a project car now to keep me busy for a while so I picked up a 95 shell on my birthday last year with almost no rust, no front end, pretty bad interior and no drive train.
The plan is a 5-600hp 1jz street / track car.
I'm not a drifting person, more of a lock it up on the highway guy.
Trying to get the car running and tuned by the end of this year. Will hold paint off till 2017 due to funds.
The shell, it came with no front end parts and a stock se wing. I pieced together a zenki front end and found a oem kouki wing on ebay japan for $175usd shipped
Brought the engine home sometime during the last week of January this year. 1jzgte non vvti with auto trans out of a chaser. I'll be using a 5spd z32 na trans with adapter from collins. Not a fan of the r154.
Got the z32 trans for $100...needs some cleaning.
Removed the auto trans and got the motor up on a stand. Removed both manifolds and stared the tear down. I'll be throwing in all new gaskets, oil pump, water pump, tensioners, pulleys, belts, cams, springs & retainers. Basically going to freshen up the motor and make it look pretty before it gets dropped in.
Test fit my modified manifold. Welds have been cleaned up, ports cleaned up, braced it and had a t3 flange welded cause I'm going with a holset he351 turbo. Also picked up a old school tial external flange type wastegate and cleaned it up a bit.
Holset he351cw...good for 700hp. Should spool quick as it has a similar exhaust size as a hy35 but a compressor side slightly bigger than a hx35. Needs to be clocked
Took the head off to get hot tanked and glass beaded. Also hot tanked the lower intake manifold runner, upper and lower oil pans and oil filter housing. Just to get things cleaned up. I had them done at machine world in LI NY.
Removing crank pulley with sst tool
Painted the block while the other parts were at the shop getting cleaned up. Also decided to powder coat the upper oil pan, turbo compressor side and lower manifold runner where fuel rail bolts on to. Will post pics of them once I get them back. Pic of the painted block. Used VHT Gloss Black Engine Enamel
Finally all the stuff I ordered from driftmotion came in.
ARP Headstuds
Brian Crower spring & retainer set
Brian Crower 264 camshafts
Tomei adjustable cam gears
New oem serpentine tensioner and timing idler pulley
Pulley set
Rebuilt 160amp alternator
Timing and serpentine belt w/o AC
Timing tensioner
Oil pump
Water pump
Also picked up some gauges and mounts / brackets from enjuku racing
AEM boost and wideband. Still need to buy a oil pressure and maybe egt gauge
Got 2 AEM fuel pumps for a deal locally. Don't know if I want to run them now after doing more research. I want to run e85 but these say they're not recommended for it. Any opinions guys? Part number 50-1000
More deals, got this cx front mount for 50 bucks on craigslist...its pretty big
New Vibrant turbo back. 3inch inlet & 4inch tip. $60 bucks shipped from the supra forums on facebook
CTSV 4 pot front calipers. Randomly searched for brembo calipers at 3am one night and found these as a pair in a scrap yard in Ohio for $150 shipped.
Also have 300zx tt rears...will get a pic after rebuilding them
Apexi avcr boost controller with boost by gear with solenoid and harness. Got locally for $200 which is a steal
Greddy oil catch can
Energy suspension poly bushings
subframe, diff, rack, rlca and I think flca
Got a set of Authentic bride digo 2 seats and 4 point takata belts with cam lock
That's pretty much most of the parts I currently have, still need a lot more things....slowly but surly.
Got the head back and did a quick mockup to see how things were looking.
Also picked up a drift motion intake manifold. I know people say these wont clear the bmc, but I prefer this style manifold over stock, it flows slightly better, just might have to modify it a bit towards the back or run the bmc delete.
DriftMotion finally sent out my OEM 1JZ full gasket set after being on back order.
Will update in a few days once I get the parts back from getting powder coated. Will put the head back together in the mean time.
Stay tuned.
SLYDEWAYS 96 is offline   Reply With Quote
