Old 08-01-2011, 10:53 PM   #1
lg54
lg54 is an unknown quantity at this point
240sx massive wheel hop.
Hey guys,
ive been having issues with wheel hop. Its really starting to annoy me, specially when i see other 240's doing burnouts and donuts really smooth. Ok, so when i launch from a dig, i get massive wheel hop. Also, when i initiate donuts, or even try to do a burnout.
I've installed SPL solid subframe bushings, checked most of my rear bushings which seem good, installed godspeed arms + sway bars (all of them are tight), Tein HA coilovers (played around with stiffness) , 245 series tires, welded diff.
Also, my car is pretty much leveled, but my coilovers are not, in order to get the car leveled, i had to give more compression(turns) to one of the coilovers.
This is really starting to annoy me. Please help me out.
thanks
lg54 is offline   Reply With Quote
Old 08-02-2011, 10:01 AM   #2
Mishkin_707
Mishkin_707's Avatar
Mishkin_707 is an unknown quantity at this point
How old are your coilovers? What engine or mods do you have done?
Could be one of your coilovers going bad? You did say you had to stiffen one more. Maybe just not enough weight in the rear for the "power" you have?
Mishkin_707 is offline   Reply With Quote
Old 08-02-2011, 02:10 PM   #3
lg54
I have an RB20, fmic, 25 turbo, 10psi tuned with a safc. My car is gutted all the way, and It could be not enough weight at the back. But, what I'm mainly looking for is doing a smooth burnout without wheel hop, not looking for traccion. I bought my coilovers used but in great shape, no leaking or anything. Will try reduncing my tire size to 225 series.
Also, I will try to post pics of what I mean with the height of coilovers.
Old 08-02-2011, 05:37 PM   #4
lg54
Ok here are some photos.
Here you see the passenger side wheel is a bit further out. Also, you can see the passenger side needs a bit more low.
Here you see Driver side coilover
Here you see Passenger side coilover
Here you can see driver side coilover. you can see there is a bit of thread left for adjusting.
Here is the Passenger side coilover. you can see there is too little thread left for adjusting height.
With this pictures im showing you my problem. The driver side is more compressed than the passenger side, and still i need to give the passenger side more low (un- compress it more). Why could this happen? could this be the problem of my wheel hop? THis car has not suffered any big accidents. I already changed the whole subframe assembly but no luck. please help me out guys
Old 08-03-2011, 01:29 AM   #5
Mishkin_707
Preloads on the coilovers? I think the coilovers may be it, the passenger side has no room for adjusting on the collars and the spring is less compressed than the others making more spring travel
Old 08-03-2011, 01:33 AM   #6
Mishkin_707
Try to rock the car on the passenger side rear and see how much bounce you get than the driver side rear
Old 08-03-2011, 10:21 AM   #7
lg54
sure ill try! also, ill try taking better pictures.
BUMP! help!
Old 08-03-2011, 10:26 AM   #8
808drft
808drft is an unknown quantity at this point
I know you said your bushings look good in the rear but recheck the lca bushings. I had this problem while drifting and found out my lca bushing were shot. The rubber fell out when I took off my lca.
808drft is offline   Reply With Quote
Old 08-03-2011, 12:24 PM   #9
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
Lol, he clearly "lowered" the car by adjusting the preload.
lg54, you need to set the springs back to how they were (even) and adjust height by twisting the coilover housing instead.
Old 08-03-2011, 12:27 PM   #10
lg54
Im going to try this, but the coilover housing doesn't twist. i guess these are not heigh adjustable?
Old 08-03-2011, 12:45 PM   #11
lg54
passenger side feels with less bounce, and feels alot more stiffer.
Old 08-03-2011, 02:55 PM   #12
Garber
Garber is an unknown quantity at this point
drivers side is probably blown. there should be almost no bounce
Garber is offline   Reply With Quote
Old 08-03-2011, 03:09 PM   #13
lg54
yeah, the bounce is very minimal and very stiff.
Here is the setting i had. i will try leveling them to see what happens.
Old 08-04-2011, 05:06 PM   #14
lg54
BUMP! help!
Old 08-04-2011, 05:11 PM   #15
KiLLeR2001
Trader Rating: (46)
The coilover on the left, make it the same as the right one, install back on car and see what happens. Honestly I'd get a new set of coilovers... lol
Old 08-07-2011, 05:49 PM   #16
jakins
jakins is an unknown quantity at this point
yah, either you struts are blown OR possibly if you have shortened sway bar endlinks, there could be alot of tension on the sway bar pulling up one of the wheels maybe.
450sX-TREME!!!
jakins is offline   Reply With Quote
Old 08-07-2011, 05:51 PM   #17
lg54
ill take a look at this
Old 08-07-2011, 06:41 PM   #18
singlecamslam
singlecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymore
Those look like godspeed arms on all your car, if it is i can almost guarantee you that each one of those bearings is lose and needs replacing.
Nothing says racecar like a stock car with no interior.
singlecamslam is offline   Reply With Quote
Old 08-07-2011, 07:57 PM   #19
lg54
Yeap there all godspeed. They are fairly new and i don't think the bearings are lose. how can i check this?
Old 08-09-2011, 01:59 PM   #20
matts13vert
matts13vert's Avatar
Trader Rating: (31)
matts13vert is an unknown quantity at this point
Feedback Score: 31 reviews
Get new coils.. those teins are tired and need to be put down.
matts13vert is offline   Reply With Quote
Old 10-09-2011, 11:41 AM   #21
arteagasilvia
arteagasilvia is an unknown quantity at this point
Send a message via Yahoo to arteagasilvia
I have the same problem !! My wheels hops, also when i make a hard right and gas half way, it hops like a bitch. My 240 is completely stock too! any ideas???
arteagasilvia is offline   Reply With Quote
Old 10-16-2011, 08:32 PM   #22
justinbyrant
justinbyrant is an unknown quantity at this point
dude don't get new coils, unless you have a couple grand just laying around doing nothing, i have ha's on my car and i love them, yours do look pretty tired but if you send them in to tein they will rebuild them, all new seals and everything, they will even put a Teflon coating on the threads to eliminate the rust, they do that all for 80$ a coil, and you can order some different tension springs when you send them in so you can really fine tune the coils.
anyways...
i have a buddy with a ca18 in his hatch with almost the same problem, and it looks like yours has the same thing wrong, before he got his car someone had drifted into a curb or something and shifted his whole sub frame to the left which is exactly what looks like happened to yours with the passenger side sticking out.
anyways it cause super uneven pressure on his back wheels any time he tried to drift because all his suspension settings were set equal instead of mismatched to correct the damage.
now im not saying leave your coils as they are because they need to be adjusted the same or you will get different tensions but try setting your godspeed stuff up not to match each other but to the degrees the wheels need to be at
justinbyrant is offline   Reply With Quote
Old 10-16-2011, 08:46 PM   #23
shanes14
shanes14 is making his/her stupidity well-knownshanes14 is making his/her stupidity well-knownshanes14 is making his/her stupidity well-knownshanes14 is making his/her stupidity well-known
i have blown to shit coils on my car with all stock rear arms and stock worn to shit subframe bushings with welded diff. i have no wheel hop problems. i dont think it would be his coilovers. but, im also on 205 tires... hmmmm
shanes14 is offline   Reply With Quote
Old 11-08-2011, 08:18 PM   #24
92SEric240sx
92SEric240sx's Avatar
Trader Rating: (32)
92SEric240sx is an unknown quantity at this point
Feedback Score: 32 reviews
Could be tires, gravel/grit on the road surface, or the surface itself
RELAX BRO!!!!
92SEric240sx is offline   Reply With Quote
Old 11-09-2011, 02:01 PM   #25
tankerhog
tankerhog's Avatar
tankerhog is an unknown quantity at this point
Try stiffiening the dampeners, if they are adjustable....I softened my coilovers and now I wheel hop doing burnouts, I didn't before when it was stiffer. My coilovers are new 8k springs in the back with 235's
tankerhog is offline   Reply With Quote
Old 11-09-2011, 07:59 PM   #26
Driftbandit
Driftbandit's Avatar
Driftbandit is an unknown quantity at this point
Dude I'm as proud as the next guy and love DIY to save money, but get a professional alignment!!! Suspension does not fall in the "horseshoes and hand grenades" category! Close enough won't work! Every piece of your rear susp is adjustable and you can't just eyeball things like toe/ camber/ caster/ ride height. Find a reputable shop to do the work. They'll probably find your wheel hop issue too. Everyone posting in this thread has given you great advice, but we can't inspect or align your car from here, so get the alignment.
Driftbandit is offline   Reply With Quote
