Old 01-06-2012, 08:10 PM   #1
ixfxi
Guest
Posts: n/a
R34 GT-R Gold Brembo Front Calipers - Fully Loaded
Sold
Close thread
Old 01-07-2012, 03:23 AM   #2
Bernie (NoVA)
Bernie (NoVA)'s Avatar
Trader Rating: (363)
Bernie (NoVA) will become famous soon enoughBernie (NoVA) will become famous soon enoughBernie (NoVA) will become famous soon enoughBernie (NoVA) will become famous soon enough
Feedback Score: 363 reviews
You have a fair bit of misinformation here.
These use the exact SAME size pad as the Z33 / G35 Brembos.
Additionally the only difference between this caliper and a Z33 / G35 Brembo caliper is a ~2-3mm difference in offset - which means to use these w. Z33 rotors you'd need to shim the caliper out a little. I have personally done this install on a friends car.
Also as for size the Nissan application Brembo calipers pads are SMALLER then the ~2008 EVO. I have installed the EVO calipers as well and they are larger then these.
350z Brembo Pad Dimmensions:
Evo Brembo Pad Dimmensions:
Bernie (NoVA) is offline   Reply With Quote
Old 01-07-2012, 11:26 AM   #3
ixfxi
Guest
Posts: n/a
Sorry, I meant to say thicker. Shape, width, length are the same. Thickness is different.
evo brembo = 585
z33 brembo = 610
r34 brembo = 660
there, now we have our facts straight.
Old 01-07-2012, 11:14 PM   #4
Bernie (NoVA)
evo brembo = 585
z33 brembo = 610
r34 brembo = 660
Hawk lists pads for the R34 in 575, 590 and 660 depending on compound etc.
I don't see what functional difference how thick a pad is will give you aside from pad life.
I can't tell any real casting difference vs. a set of 350z calipers...
Old 01-08-2012, 11:55 AM   #5
ixfxi
Guest
Posts: n/a
i have a good solution for you
buy these calipers, then you can put them side by side and measure them with a caliper ALL day long. i've done that, now you can too!
just curious, have you actually had these calipers and the z33 calipers, or are you just getting your information from online vendors and sources? im just asking, because ive had them both. not saying this to talk shit, because my memory is not 100% accurate but its pretty spot on (usually)
Old 01-09-2012, 12:50 AM   #6
Bernie (NoVA)
I have owned & installed both R34 & Z33 Brembo calipers on Z32s.
I also have a set of Evo Brembos on my S14.
Old 01-07-2012, 04:57 AM   #7
sincity_sil80
sincity_sil80's Avatar
sincity_sil80 is an unknown quantity at this point
good to know^^ , OP GLWS, wish i had the flo
20 till 3:00 =
sincity_sil80 is offline   Reply With Quote
Old 01-07-2012, 10:35 PM   #8
racer98
racer98's Avatar
Trader Rating: (128)
racer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant future
Feedback Score: 128 reviews
Send a message via AIM to racer98 Send a message via MSN to racer98
I was talking with someone else about this vs the USDM market Z33 V35 brembo once I get a set in will post some pix showing the difference.
racer98 is offline   Reply With Quote
Old 01-07-2012, 10:42 PM   #9
ixfxi
Guest
Posts: n/a
i had a full set of z33 brembos years ago. there certainly is a difference.
Old 01-07-2012, 10:47 PM   #10
EsChassisLove
EsChassisLove's Avatar
Trader Rating: (26)
EsChassisLove is an unknown quantity at this point
Feedback Score: 26 reviews
Those are beautiful. GLWS.
IG/TikTok-ThatS14_Z06guy
EsChassisLove is offline   Reply With Quote
