Old 02-25-2012, 02:41 PM   #1
rcl1221
rcl1221's Avatar
rcl1221 is an unknown quantity at this point
Any drawbacks to running a smaller wheel at the track?
I drive an NA KA 240. I've been running 17x9.5 wheels at the track, but I'm looking to go to a 16x8.5 setup this season.
Will turn in be softer due to the increased sidewall?
How is tire availability with 16s? Seems like 17+ has more available these days.
Sent from my Motorola STARtac using Tapatalk
rcl1221 is offline   Reply With Quote
Old 02-26-2012, 05:35 PM   #2
freeagent3117
freeagent3117's Avatar
freeagent3117 is an unknown quantity at this point
it really depends on the size tires your gonna be running. The same sidewall tire on a 16 or 17 wont really matter if the tire sizes are the same. ex:205/40/16 vs 205/40/17 it would only change the speed per revolution. fatter sidewall would have less response and more flex. just my o2.....
freeagent3117 is offline   Reply With Quote
Old 02-26-2012, 07:09 PM   #3
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
If you're worried about having more sidewall, get tires that has stiff sidewalls. What tires are you looking on running to begin with? Personally, I'm partial to running Dunlop Star Specs up front. Advantage of running smaller rims is less weight...lets it easier to kick the rear end loose.
CLICK HERE!!!
Old 02-26-2012, 08:29 PM   #4
rcl1221
rcl1221's Avatar
I'm talking about roadcourse days. When drifting, I already use 16s in the rear as drift spares.
Looking around, not a lot of choice for sticky 16in tires. I'd try my best to keep the same rolling diameter.
Old 02-26-2012, 09:36 PM   #5
fliprayzin240sx
If you want sticky tires, R-comps are the way to go. I was gonna say Nitto NT01s but they only got one size for 16s (245/50-16). Thats too wide for 8.5j. Hankook Z214 are the next best choice since its fairly cheap compared to Hoosiers or Kumhos.
CLICK HERE!!!
Old 02-29-2012, 11:06 AM   #6
mr.man.performance
mr.man.performance's Avatar
mr.man.performance is an unknown quantity at this point
Agreed on the slim tire selection, especially compared to 17's and 18's. If you already have your suspension setup the way you like it, I don't think changing wheel size down will make any real positive impact.
If the tire widths and profiles and wheel widths are the same, going down an inch will reduce steering feedback due to a reduced scrub radius. Personally, I like having a very tangible steering feel. As far as the characteristics of the car is concerned, not much will change at all besides a different speed:wheel rotation ratio.
mr.man.performance is offline   Reply With Quote
Old 02-29-2012, 11:09 AM   #7
mr.man.performance
Also dependent on offset and camber. What are you looking to achieve? What don't you like about the 17's?
