Old 02-29-2012, 09:43 AM   #1
S_13_Sr.
S_13_Sr. is an unknown quantity at this point
SOCAL COMPLETE ka24de with trans
selling my ka24de engine, it has 135,xxx miles on it NOT LOOKING TO PART OUT
currently in my car if you want to come look at it. I'll drive you around. it starts up fine and doesn't over heat. trans doesn't grind clutch is ok for dd'ing but will need replacing if you plan on abusing it.
doing an SR swap next Monday so the engine will be out beginning of next week
buyer picks up (swap will be done in Ontario) currently located in 626 area.
just had some work done last week. 2/23/12 performed at g-dimension in Fullerton
timing was done
new injectors and seals
new spark plugs
new oem fuel regulator
coolant flush
valve cover gasket was replaced when timing was done
ecu was checked and all codes cleared besides the automatic trans (auto trans ecu)
$800
NEW DIRT CHEAP PRICE READ BELOW
best way to get a hold of me is txt (626) 3.4O-five four 3 I
REASON FOR SELLING... THIS IS MY FIRST NON SR 240 AND I WANTS MORE POWER
coming out of this
S_13_Sr. is offline   Reply With Quote
