Old 11-21-2003, 02:40 PM   #1
climo
climo is an unknown quantity at this point
Strange Vibes from entire car
I recently purchased my 98 240 about 2 months ago. Everything is fine except for a numbing vibration felt thru the whole car. Idle quality is great so no problems there. Once I rev it to 2k rpms then the car starts to vibrate. You can really feel it thru the steering wheel and inside the car. My rearview mirror shakes until I lower the rpms below 2k. The engine doesn't seem to shake or anything just that you can feel it when leaning against the car.
I checked for items contacting the body but no luck. other than the vibes it runs great. The steering wheel makes my hand go numb after a few hours driving. I also checked the motor mounts and they don't seem to bad. Little movement when power braking.
Idle is smooth, exactly at 2k rpms you can feel the vibe. Above 2k you can still feel it but but not as noticeable. Oh yeah this is in park sitting still. It does have 187k miles but like I said its BONE dry underneath the car.
any ideas?
climo is offline   Reply With Quote
Old 11-21-2003, 09:21 PM   #2
misnomer
misnomer's Avatar
Sounds to me like something is off balance. . . I don't know how you'd narrow it down. Feel around, see if you can feel it from the block, transmission. . . mebbe accessories. . .
Keep in mind the KA24 is a relatively shakey engine. I wouldn't say palm numbing, but it's definitely not as smooth as other cars I've driven.
Old 01-21-2004, 10:06 PM   #3
TachyonS14
TachyonS14's Avatar
TachyonS14 is an unknown quantity at this point
Send a message via AIM to TachyonS14
Climo, I and a few others over on the NICO board have the same problem. I have a 97 240 and right at 2krpms, I get the same thing. I've been trying to fix this problem for 7 months! I've done everything I can think of, so If you do find a solution please don't forget to post It, thanks!
TachyonS14 is offline   Reply With Quote
Old 01-22-2004, 08:12 AM   #4
tsunami0ne
tsunami0ne is an unknown quantity at this point
any ideas?
I'm probably wrong since you says this happens after 2k, but check your tire tread. If you can move it around with your fingers, then that is bad.
tsunami0ne is offline   Reply With Quote
Old 01-22-2004, 12:56 PM   #5
Brolewigi
Brolewigi's Avatar
Brolewigi is an unknown quantity at this point
Have you done anything to your suspension latley? I could be something as simple as your alignment. I got snow stuck in my wheel and it made the wheel off ballanced. But since you live in Cali that shouldn't be a problem. Your tires could also be unballanced too.
Brolewigi is offline   Reply With Quote
Old 01-22-2004, 02:01 PM   #6
Chernobyl
Chernobyl's Avatar
Chernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond repute
He said the problem is in park, sitting still, so that excludes any driveline balance. Check your computer for codes. It might not show the check engine light, but there still might be something broken, and it will spit the code for it.
Chernobyl is offline   Reply With Quote
Old 01-22-2004, 04:29 PM   #7
hookedup240
hookedup240's Avatar
hookedup240 is an unknown quantity at this point
Send a message via AIM to hookedup240
any ideas?
Holy shit, 187k miles on a 98 that is a lot.
Sorry i couldn't be of any help
hookedup240 is offline   Reply With Quote
Old 01-23-2004, 02:28 AM   #8
TachyonS14
TachyonS14's Avatar
I have the same problem, and I'm going to try this tomorrow http://www.240sx.org/faq/articles/idleirreg.htm Seems 240's have a common problem with the throttle plate getting dirty, and same with the IAA valve.
1997 240sx 5spd
