Old 03-07-2012, 07:21 PM   #1
shoguner
shoguner is an unknown quantity at this point
Ka24det 565cc z32 maf HELP!!!
I am having major problems with my ka24det.
http://www.facebook.com/v/10150597532666365
i have
565cc (sti injectors)
z32 maf
new rings/bearings.
stock cams.
t3 ebay turbo .60ar
Whether i unplug the maf or not it runs the same.
Running the
""Here are a few tunes for a 555cc t3t4 z32 maf setup. Run on 9:1 CR and the octane is in the title (of the tune file). Also these are a little conservative because I got ceramic coated pistons and combustion chambers so I have to run less advance due to the faster combustion of the coatings. I still recommend 1*/psi for 91 octane.
Zero vacuum is at (TP) load column 54. I make about 8psi through a cat and stock exhaust at 81 and 10psi open dump exhaust at 108.
http://www.liquidmathematics.com/tun...c11at10psi.bin "
Tune
would 10cc's really do that?
Also i am seeing maf voltage at the ecu...
Any ideas?
also the safc wont change any of the afr no matter how much i go up or down....
shoguner is offline   Reply With Quote
