Old 07-06-2012, 10:01 AM   #1
Titan
Titan is an unknown quantity at this point
KA24ET – Hard to start when cold – Fuelling Issue
Hey guys, it’s been a while since I posted here, but this has always been the best place for technical advice.
A few years ago I turbocharged my S13 KA24E with a T3. Basic details: FMIC, SAFC, 370cc CA18DET injectors, Walbro 255. The car ran great after the build for many years.
Since then the car has been sitting for the past year as I bought a daily driver (Mazda 3... very exciting I know). I have been busy reviving the car over the past 2 months and at the very end I've run into an issue. The car was running fine before it was stored.
The engine is very difficult to start when cold and I am certain it is a fueling issue.
It will turn over, but won't catch until I return the key to accessory on. After it fires it will almost immediately stall. The process will need to be repeated several times while blipping the throttle in order for the engine to remain running. Once it warms up there is hesitation and backfiring under throttle, but at least it remains running. Removing the plugs yields a flooding scenario.
I have performed an inspection or replaced the following parts / systems:
- Fuel pressure is consistent while priming, cranking, and running (40 psi)
- Injectors have been cleaned and flow tested on a bench last week
- New fuel filter
- Fresh fuel in the tank
- Checked MAF (Hotwire is clean)
- Checked IACV (Ports are clean)
- SAFC settings same as when car last ran well
- No ECU error codes
- Resistance of ignition coil is in spec (primary and secondary)
- New rotor
- New distributor cap
- New plugs and plug wires
- Spark is present on all cylinders while cranking (checked each cylinder with a spare plug grounded to the engine block)
- SAFC reading proper TPS signal
- Coolant temp sensor resistance in spec
- Air regulator valve is getting 12v signal when key is in accessory on
- New battery
- Rebuilt alternator
I have tried playing with the SAFC and base timing, but neither has given me proper results.
I have literally tried everything I can think of in addition to following FSM troubleshooting procedures. No avail. I would be very grateful if anyone has any ideas / solutions, as I`ve exhausted all my troubleshooting knowledge.
Sleep Doesn't Drink Beer
Titan is offline   Reply With Quote
