Old 06-26-2012, 07:28 PM   #1
Breareos
Breareos's Avatar
Breareos is an unknown quantity at this point
Question can single plate clutches be equal to multi plated?
I'm specificallly wondering if Exedy's hyper single clutch can compare and be equal to ORCs triple plated multi plated clutch. What are the pros and cons to each? Could Exedy's be able to handle 400-500hp? I'm not very experienced with knowing which part is right for my car but I want to become informed.
Breareos is offline   Reply With Quote
Old 06-26-2012, 07:34 PM   #2
silver350z05rb
silver350z05rb is an unknown quantity at this point
I had the hyper on my s15 which made 497whp, held up awsome, triple plate should hold at least that or way more
silver350z05rb is offline   Reply With Quote
Old 06-26-2012, 08:09 PM   #3
Breareos
Breareos's Avatar
So what you're saying is multi plate clutches can hold more power...
And that's good to hear, 500whp would be the most I'd want to have.
Old 06-26-2012, 08:30 PM   #4
SR20DETpwr
SR20DETpwr is an unknown quantity at this point
I wouldn't go with a really strong clutch if you don't have to. If you can get away with an organic material and sprung hub - do so. It is easier on the tranny.
SR20DETpwr is offline   Reply With Quote
Old 06-26-2012, 08:52 PM   #5
silver350z05rb
Another clutch i've also had was a OSgiken twin plate,was as soft as the exedy hypher,mmmhhhj, no experiance with a triple,but just that I drove an RB with one but it had a nismo slave,it.was also bearable
Old 06-26-2012, 09:16 PM   #6
cotbu
cotbu's Avatar
Honda clutches are rated by Horse Power
Nissan clutches are rated by Torque
Hello Honda Dudes!
Old 06-26-2012, 10:42 PM   #7
Breareos
Breareos's Avatar
Hondas? DO NOT WANT!
Hello Honda Dudes!
Ughh, I am NOT a honda fan! Blech! I've heard WAY too many wet fart civics in my city to even remotely be a fan!
I'm new to this so excuse me for not knowing that.
Old 06-26-2012, 10:43 PM   #8
Pinggg
Pinggg's Avatar
Trader Rating: (22)
Pinggg is an unknown quantity at this point
Feedback Score: 22 reviews
I heard of some Exedy Hyper Single failing right under 400tq, there's a few threads on here if you search..
Multi plates clutches are definitely stronger then singles just because the extra pressure plate.
2 pressure plate > one pressure plate.
Pinggg is offline   Reply With Quote
Old 06-27-2012, 11:03 AM   #9
jr_ss
Twin/triple plate clutches only have one pressure plate. The advantage to a multi-plate setup is you have more surface area for the clutch to grab. This allows them to hold more power while also keeping the PP clamping load lower. In order for a single plate clutch to hold equal amounts as a multi you have to ramp up the clamping load on the PP. This in turn creates the "heavy" clutch feeling. The more clamping load, the heavier they are, generally speaking anyway. There are a lot of other factors that go into making a good clutch though.
