Old 10-13-2012, 05:28 PM   #1
Volchok
Volchok's Avatar
Volchok is a splendid one to beholdVolchok is a splendid one to beholdVolchok is a splendid one to beholdVolchok is a splendid one to beholdVolchok is a splendid one to beholdVolchok is a splendid one to beholdVolchok is a splendid one to beholdVolchok is a splendid one to beholdVolchok is a splendid one to beholdVolchok is a splendid one to beholdVolchok is a splendid one to behold
Send a message via Yahoo to Volchok
1992 s13 FD legal track car $8900 OBO.
It is a bitter sweet day for me as I put my pride and joy up for sale...
Over $30k invested and over 500 hours of labor...
I used this car for several seasons of Vegas Drift Pro Am series and can no longer afford to drift. I am getting older and it is time to move on and be more responsible, stop blowing $1k a day for fun... I hate looking at it every day in the garage, knowing it isn't being used and abused like it should be...Right now I am trying to sell the car as a whole, not part it out. No point is PM's or questions about individual parts. If it doesn't sell as is, I will repost with parts pricing at a later date.
Must be a good loving home with intentions to drift the s**t out of the car, not hard park it.
1992 Nissan 240SX - clean title in hand
ENGINE
Apex'i Power FC DJetro for s13 SR20DET with all sensors and commander - Tuned by DDS performance - 336 hp at 18 psi - 355 hp at 20 psi
SR20DET - freshly rebuilt bottom end from Get Nuts Labs
rebuilt top end from DDS Performance
Built SR20DET
S15 pistons
Apexi 1.1 mm metal Head Gasket
Brian Crower Stage 2 264 cams
Peak Performance Valve Springs
ARP Studs
new seals, spark plugs, bearings, water and oil pump
Circuit Sports Anodized blue pulley kit
Nismo Motor Mounts
Greddy Large Oil Pan
Full Race twin scroll T3 manifold, dual wastegates
2 x 38 mm Tial MVS wastegates Blue with Full Race Logo
Tial Q BOV blue with Full Race logo
Full Race SR20 RWD Downpipe for twinscroll T3 dual wastegate
Custom intake manifold with 90mm throttle body
Custom exhaust from DDS Performance
Custom front bash bar from DDS Performace
Garrett GT3071R turbo t3 .78 AR twin scroll housing 3" v band
Koyo Radiator with dual Flexalite Fans
4" Full Race Intercooler
Custom V-Mount intercooler/radiator setup done by Forrest Wang - Get Nuts Labs
custom front wheel well tubs done by Forrest Wang - Get Nuts Labs
Full Race custom oil catch can
Get Nuts labs custom coolant reservoir
Get Nuts labs custom power steering resivoir
Greddy Water Temp Adapter
RC engineering 1000cc injectors
Sard Fuel Pressure Regulator
Sard Fuel rail
HKS Fuel Rail Adapter
Tomei Fuel Pump
Earls Fuel Lines
**all lines and hoses are AN fittings with black Prolite or Steel braided hose, there is not a single rubber hose or hose clamp on the entire car.
Summit racing battery relocation kit
Taylor Master battery disconnect switch
Full Painless wiring harness and Painless switch - wired by Garage Vegas
Greddy oil cooler with fan
Greedy oil filter relocation kit
Earl's power steering cooler with steel braided high pressure lines
Gauges
Defi Blue Racer:
- Oil Temperature
- Oil Pressure
- Water Temperature
AEM UEGO Wideband
SBC i-color boost controller with Fuel pressure sensor - amazing boost controller
Cobalt Blue Tachometer
Cobalt Blue Volt meter
Cobalt Blue electronic fuel gauge
SUSPENSION/DRIVETRAIN
Stance Gr+ coilovers
Kaaz 2 way LSD - always used Torco fluid and modifier
SPL transmisison mount
competition Clutch twin disc carbon composite clutch with lightweight flywheel
SR20DET transmission (spare transmission included)
Rebuilt steering rack
Rack & Pinion Bushings
Circuit Sports Steering column spacer
Battle Version Tension rods
Tein Inner Tie Rods
Tein Outer tie Rods
Battle Version Rear Upper Control Arm
Battle Version Traction Rods
Battle Version Toe Arm
B & M Short Shifter
Circuit Sports Subframe Bushings
Energy Suspension end link and sway bar bushings
Get Nuts Labs custom steering angle kit with tie rod spacers
Hydraulic e-brake
INTERIOR
Bride Super Low FG Rails
Sparco Black Suede Monza Wheel with blue anodized hub
NRG Qucik Release Hub Gen 2.5
Sparco Pro 2000 Seats
Sparco 3" Harness Pads
Corbeau 5 Point Harness
Blue JDM Dildo shift knob
MOMO Pedal Kit
MOMO Floor Mats - steel
Full Race 6 Point Cage - built by Forrest Wang
BRAKES
Circuit Sports Front Rotors
Circuit Sports rear Rotors
Front and rear Steel braided lines
5 Lug Conversion
Z 32 Front brakes Brakes
Z 32 Rear brakes
Z32 Steel Brake lines
Hawk Racing Pads front and rear
EXTERIOR
Origin 30 mm front over fenders
50 mm origin rear over fenders
Carbon fiber hood with hood vent
Sparco anodized blue hood pics
Uras knockoff body kit
Paint and body work done by Spring Mountain Autobosdy
Engine bay painted with House of Color silver flake done at Garave Vegas
H4 Headlight Conversion
HID Headlights 8000k
Enkei RPF1 Rims white 17x9 - Front
Enkei RPF1 Rims white 17x10 - Rear
Extra set of Enkei RPF1's 4 x 17x10 rears
Currently has new Federal 595 245/40/17 on the rear
Brand new set of Federal 595 245/40/17 included
4 x 245/40/17 used tires
Toyo Proxes R1R front tires - well used
summit racing tow hooks
Also included:
GForce GF525 Racing driver suit in black - large
GForce G5 Gloves black
I think that about covers it. If I think of anything else I will add it.
THE BAD: the car does have a little battle damage, which is cosmetic only thus I never got around to fixing it.
right rear quarter panel and tail light has damage from wall contact and a small collison with Danny George at FD Las Vegas
front bumber is cracked
rear bumoper is cracked/damaged from said Crab Broker contact
I am asking $8900 OBO for everything listed - an amazing steal even in today's market, my loss is your gain.
Pics:
Volchok is offline   Reply With Quote
240 sx, 3071, enkei rpf1, full race, get nuts lab
