Old 02-19-2004, 08:03 PM   #1
twitchy
twitchy's Avatar
twitchy is an unknown quantity at this point
Silly Header Question
Hey all
This might be silly but its new to me....
Heres my current exhaust setup:
Stock manifold
Stock Cat
no resonator
half inch oversize plumbing
stock muffler
what I wanna know is when i install my header, would it be totally useless if I just upgraded the cat and kept everything else the same?
Who the hell needs a sig anyhow
twitchy is offline   Reply With Quote
Old 02-19-2004, 08:44 PM   #2
Ghettokracker71
Ghettokracker71's Avatar
Ghettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enough
Send a message via AIM to Ghettokracker71 Send a message via Yahoo to Ghettokracker71
Originally Posted by twitchy
Hey all
Stock manifold
Stock Cat
no resonator
stock muffler
I am kinda interested in this myself! I want to have my header in before I have my high flow mounted,and my exhaust bent up....so I am only mildly interested b/c I won't keep the other stuff stock long....ANYWAY
Twitch-I think it will improve performance,but minimally....I know people who have done headers on a otherwise stock V8,with stock exhaust,and it made a nice difference,but I don't know about the 240
Ghettokracker71 is offline   Reply With Quote
Old 02-19-2004, 09:11 PM   #3
sykikchimp
WOW addicted
sykikchimp's Avatar
I've seen header dyno's with 10-12hp gains. good stuff depending on which ones. It will only help.
I think hotshot may delete the cat.. so check on that.
Old 02-19-2004, 09:14 PM   #4
XxJaPxOxNeEs23xX
XxJaPxOxNeEs23xX's Avatar
XxJaPxOxNeEs23xX is making a name for him/her selfXxJaPxOxNeEs23xX is making a name for him/her self
Send a message via AIM to XxJaPxOxNeEs23xX
if u get new headers dont u hav to get a new precat. that has the o2 sensors on it. but no one sells that.
XxJaPxOxNeEs23xX is offline   Reply With Quote
Old 02-19-2004, 09:15 PM   #5
Ghettokracker71
My OBX Racing header DOHC S13 has an 02 sensor bung on it....I'm pretty sure!
Old 02-19-2004, 09:16 PM   #6
sykikchimp
WOW addicted
sykikchimp's Avatar
what's a precat? all you need is a bung in the exhaust to mount an o2 sensor.
Old 02-19-2004, 09:44 PM   #7
XxJaPxOxNeEs23xX
the cat converter that goes before the cat converter. were the o2 sensors connect to. its after the headers but before the cat. i mean isnt that wat it is. the thing were the o2 sensors conenct to. also if i dont do that it wont be smog leagal
Old 02-20-2004, 08:45 AM   #8
twitchy
twitchy's Avatar
my car will have an 02 sensor AND a cat....I Have to replace the o2 sensor onto the new header anyhow. Im getting a pacesetter unit BUT is using my stock muffler going to make the header useless?? I dont want to replace the muffler cause mines in good shape
Old 02-20-2004, 10:41 AM   #9
Ghettokracker71
Didn't skykikchimp already say....?? I'd say go ahead and put it on,I think it will make a difference
Old 02-20-2004, 02:16 PM   #10
Dream240
Dream240's Avatar
I have all my exhaust parts replaced and here's how I did it.
OBD-II s14
Hotshot header unit - replaces ALL part from header down to "Fake" CAT.
Installed Random Tech High Flow CAT where the "fake" cat normally goes.
And Finally the Apexi N! dual which mounts directly behine the high flow cat. Good thing about the Random Tech cat is the flanges. It doesn't require gaskets because it's self sealing.
Oh I also rewired the 2nd O2 sensor which was originally located right after the stock cat. I moved it to the Exhaust just after the new cat. Also the 1st O2 sensor is mounted to the Hotshot header in almost the exact location as the stock header. All in all my exhaust consists of 4 pieces: Header-CAT-1st muffler section-2nd muffler section.
With yours you should replace everything EXCEPT the muffler sections like you stated. Also rewire the 2nd O2 sensor like I did that way you won't get an engine light. If your is OBD-I(1 O2 sensor) then it should be the 1st one that mounts to the header, and disregard the rewire info.
Hope this helps with your set up making sense.
Also just a side note, the header WILL make signifcant power gains on the top end. Very noticable gains with your butt dyno. The stock header unit on all 240s was very restrictive. I mean just put the two side by side when you do the install and look at the pipe bends, it speaks for itself.
Good Luck
Old 02-20-2004, 01:42 PM   #11
twitchy
twitchy's Avatar
eep sorry
wicked nasty snowstorm today, already got a foot
my brains a little stiff from trying to drive
Old 02-20-2004, 03:40 PM   #12
twitchy
twitchy's Avatar
OOOOOOOOOOOOOOOOooooooooooooooooh!!! Mu ha ha ha ha ha hahahah
Old 02-20-2004, 04:01 PM   #13
Dream240
Dream240's Avatar
Uh, yeah.
Old 02-20-2004, 05:08 PM   #14
MorganS13
MorganS13 is an unknown quantity at this point
Just for reference.. an aftermarket header with an aftermarket exhaust on a KA is L-O-U-D..
I had silencers in my N1 Dual for a while (very restrictive) and there was still a noticable power gain, so I'm pretty sure you'd be happy with the results. The noise shouldn't be too bad with a stock exhaust as well.
MorganS13 is offline   Reply With Quote
Old 02-23-2004, 04:11 PM   #15
NISMO240SXSE1
NISMO240SXSE1 is an unknown quantity at this point
s13
Actually I have a Hotshot header with a high flow cat and HKS hi-power exhaust and it's not too loud.It only get's loud at high rpm,or when accelerating hard.Normal cruisin' it's not bad.
NISMO240SXSE1 is offline   Reply With Quote
Old 02-21-2004, 02:57 AM   #16
twitchy
twitchy's Avatar
morgan thats great.......yeah i dont want it to be loud- I cant wait...maybe ill record it before and after and post the sounds or something...
Uh, yeah.
um, thats what I say when im excited...think of the waiter dude on the simpsons....YEEEEEEEEEEEESSSSSSSSSSSSS!! I HAD A STROOOOOOOOOOOOOOKE.....
nevermind... I was glad to hear what you had posted was all- its all pointing me in a good direction.
Old 02-21-2004, 08:34 AM   #17
Dream240
Dream240's Avatar
Yeah I figured you were just excited. Glad to hear you getting the hang of it. Have fun modding your car!
Later
Old 02-21-2004, 02:34 PM   #18
jonsey
jonsey is an unknown quantity at this point
i just installed a new hotshot header and full exhaust (HKS)...its not loud at all untill you really step on it but the sound is amazing...not annoying at all...removing the resonator is generally what makes exhaust loud and shitty souding...go for the headers...i love it and im sure you will too...BTW hotshot does not replace the cat...i have a 93 s 13..
jonsey is offline   Reply With Quote
Old 02-21-2004, 03:08 PM   #19
MorganS13
What type of HKS?
Old 02-22-2004, 02:43 AM   #20
twitchy
twitchy's Avatar
hotshot...are these similar to pacesetter you think? Id buy the pacesetter cat back system I saw on ebay to go with it if I Hadnt seen such poor quality from the kit on my dads car........Oh, my high (er) flow cat is from a 1999 Grand Prix GTP- the cat is big, flat and can be welded to my car. I can get it from the junkyard for $15
Old 02-23-2004, 06:40 AM   #21
BlackS14
BlackS14 is an unknown quantity at this point
Send a message via Yahoo to BlackS14
I jusy installed the latest generation header from Hotshot on my car yesterday. It fits PERFECT and it's a great quality piece (with bling also...lol). Only problem I had with it was the bung for the second O2 sensor had the thred pitch for the size of the first O2 sensor. The second O2 sensor is quite smaller than the first causing it not to fit. Luckilt I still had my old O2 sensor and I just used it as a plug. I'm throwing codes from the ECU, but the second O2 does nothing amyways so no worries.
And as others have said...with the addition of the header along with my Apexi N1 cat-back...it's LOUD....but me likes!!!
-Bill
Once you go black you...well...you know.....lol!!!!
BlackS14 is offline   Reply With Quote
Old 02-23-2004, 03:39 PM   #22
twitchy
twitchy's Avatar
hey uh...you dont have to like...drop the motor or lift it do ya?? If I had the right tools and know how could i do it myself? Ill likely take it in though...how long do you figure it would take to install
Old 02-23-2004, 03:41 PM   #23
INeedNewTires
INeedNewTires's Avatar
INeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond repute
exhaust upgrades closer to the engine always make more of a difference than farther from it. so yes, a header is still good w/ stock muffler. it will be a bit louder but wont matter unless your muffler is just crap. id put back on the resonator (or any resonator the same size piping as what you have) as well as a hi-flow cat from catco. their only 50 bucks or less and flow a shitload better.
INeedNewTires is offline   Reply With Quote
