Old 07-28-2012, 02:18 PM   #1
Cubantunr
Cubantunr's Avatar
Cubantunr is an unknown quantity at this point
Mixing clutches and pressure plates..help
Ok so here's the deal I have an Sr20det redtop rwd s13 and a stage 3 spec sprung clutch. I dont want the sprung clutch I prefer unsprung but cannot find any vendors that sell spec clutch disks separately.. I found an ACT 6 puck unsprung disk and it looks about the same just wondering if you could mix match why or why not. And if there's any other recommended clutch disks lmk
Cubantunr is offline   Reply With Quote
Old 07-28-2012, 02:28 PM   #2
R@ddy
Trader Rating: (32)
R@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymore
Feedback Score: 32 reviews
Personally, I don't see why you want something unsprung unless its just a track car. You should be alright mixing and matching discs/PP as long as they are the same size (240mm)
R@ddy is offline   Reply With Quote
Old 07-28-2012, 02:33 PM   #3
Cubantunr
Cubantunr's Avatar
I've read reviews and people have told me about the springs shooting out. And on my 500hp Sr I wouldn't want to risk it :/
Also is it the pp or clutch that determines torque rating.. sorry kinda a noob still at clutches.
Old 07-28-2012, 02:43 PM   #4
bussitcustoms
bussitcustoms is an unknown quantity at this point
An unsprung clutch on an sr with 500hp will break the trans in 2 weeks, tops. If you insist on using that transmission, use a sprung clutch. SR transmissions are glass as it is... The unsprung clutches just add to that problem.
bussitcustoms is offline   Reply With Quote
Old 07-28-2012, 02:45 PM   #5
bussitcustoms
Your money would be better spent on a z33 transmission kit. With that, you could run an unsprung clutch without risking damage to the trans
Old 07-28-2012, 02:57 PM   #6
Cubantunr
Cubantunr's Avatar
I already have the complete mazworx Sr to vg kit with one piece upgraded 3 inch steel driveshaft
I guess I just want a good replacement clutch because im afraid of the spring not holding up. And Idk if ACT will do the trick. disk is fairly new.
Old 07-28-2012, 03:08 PM   #7
!Zar!
!Zar!'s Avatar
Just get a twin plate clutch if you're so worried about holding power.
Old 07-28-2012, 03:28 PM   #8
Cubantunr
Cubantunr's Avatar
If only I had the money. From the looks of it ill either just get an act 6puck disc or sell it all and get the act kit. Thanks for input guys.
Old 07-31-2012, 08:03 PM   #9
UNITEDMASTER
UNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to all
yes you can mix & match. Discs are discs. As long as dia. is the same & spline count is. for SR.
Clutch net got them discs for cheap!!!
MR JACKSON.
UNITEDMASTER is offline   Reply With Quote
Old 07-31-2012, 08:24 PM   #10
TheWolf
TheWolf's Avatar
TheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant future
To answer your question
Both pieces do. The amount of friction the material on the disc generates along with how hard it's pressed onto the flywheel by the pressure plate. Those give you the clutches hp rating. Sprung clutches are for street driving. Unsprung are for track/drifting. Compromise is key
Eye on the Prize
TheWolf is offline   Reply With Quote
