SR20DET Bare Block Damaged, needs repair, part out
I have a Redtop SR20DET bare block that needs repair on the 3rd Main journal, it spun the bearing slightly, and damaged the tang that keeps the bearing positioned correctly, one side is still good, the other broke off a little. The cylinder walls are in fantastic shape, no lip and still see cross hatching, as well as the block surface and all other journals, no metal shavings were present anywere and the bearing did not get worn down to the copper, just spun for some reason, all other bearings had zero damage. I will part out whatever small pieces you need from the block, just be sure to give me feedback once you get your parts. The crank was junk and cracked on that journal, the engine had been run for a long time, so it was not a fresh rebuild and all bearings were Nissan OEM and std sizes with corresponding colors, not just a set thrown in, knock sensor was not melted, but oil pump was definatley worn out, will include that with the block and you can replace the center section I think which is only $60 new from Nissan.
Parts available -Block W/Caps, and Girdle and mainbolts $20 +shipping and packing -Oil Squirters $30 shipped SOLD -pressed in coolant pipes in block $5 each+shipping -Front Cover (bad oil pump, no shavings) $10 +shipping -Block oil drain from catch can $5 +shipping -Rear Main seal plate (seal is still soft and was not leaking) $10 + Shipping ![]() It was dark, but I do have all these pieces, will take pics next time I go to storage. All items coming out of 77034 a fedex ship center Will do packaged deal with other items I am selling here is a link, please don't ask about items that were not posted this month. http://zilvia.net/f/search.php?searchid=11762406 Last edited by Davidna2fi; 11-09-2012 at 01:21 PM.. |
