![]() Join Date: Nov 2009
1991 Nissan 240sx Fully Built SR21 Drift Car
ASKING $7000
For Sale my 1991 Nissan 240sx Hatch Chassy Mileage: 120K miles Engine Mileage: 6,000 -7,000 Miles ; 7 Drift Events CAR WILL BE PAINTED ANY COLOR DESIRED (1 stage paint) Contact Me: 240-291-6744 dont mess just txt me for quick responce Currently it is only running on 8lbs of boost and it is making around 300-320whp. Obiously you can turn the boost up, it should be able to break 500hp easily. I am in college and I dont have time to have fun with it anymore =( Engine Mods Tyson's Machining, Sterling,VA CP Pistons; Bore 87mm Amd Eagle Rods; H Beam ARP main studs ARP Head studs ARP rod bolts ACL Race bearings(Main &Rods) ACL Thrust Washer Tomei Rocker Arm Stoppers Cometic MLS Head gasket Garrett GT3076R 64mm trim w/ Dual Ballbearing/coolant cooled (Was sent to Precision to get GT28 exhaust housing to get milled; awsome spooling!) Stainless Steel Turbo lines 3 Inch Down Pipe w/ Wideband Bung welded on Nismo Motor Mounts & Trans Mount 1 Piece Steel Driveshaft from Driveshaftshop Koyo Radiator SR20 Oem Radiator hoses 480cc S15 Nismo Injectors Power FC & Commander HKS Blow off Valve Z32 Maf Q45 throttle body Blitz Air Filter Intake Suction kit Z32 fuel Filter High Pressure Fuel lines Competition Stage 3 clutch Fidanza light weight Flywheel Nismo low temp Thermostat Nismo Fuel Pressure Regulator B&M Short Shifter(awesome!) Brand New Oil pump Brand New front & Rear Main seal Brand New Water Pump Brand new belts Fresh Transmition 1991 240sx; No Rust anywhere Mods Corner 8 Coilovers Isis Camber Arms Isis Tension Rods Isis Traction Rods Isis Toe Rods Energy Suspencion Subframe Bushings Subframe was sent to Alexander Fabrications for reinforcements. Fab work! S14 Welded Diff (Alexander Fabrications)/ S14 axles Tein S14 Inner Tie Rod ends Tein S14 Outer Tie rod ends Brand new front lower control arms Ichiba 5 lug Front Hubs w/ Extended ARP lug studs Rear S14 5 lug Hubs Brand new Front & Rear Rotors Brand new front & Rear Calipers Brand new front brake pads Brand new Brake Master cylinder E-Brake Drift Button/Mod EBrake Lever Position Isis 3 inch Straight Pipe w/ Dual 4 inch tips Isis Test Pipe Momo Steering wheel w/ Nardi Hub Rear Strut Bar Relocated Battery to rear Cons- NO HEAT, NO BLOWER MOTOR ![]() ![]() ![]()
