Old 01-21-2013, 02:32 PM   #1
Erichl504
Erichl504 is an unknown quantity at this point
s14 Car is running like crap can't figure out why!!!
Ok so my 95 s14 has been running like complete dog shit for the past month, thought it was the stock fuel pump so I replaced it with a walbro 255 and an after market fuel pressure regulator. But that did not solve the problem, when I'm cruising the car wants to buck and cut in and out like I'm loosing fuel but on a full tank???? Really!!! I replaced the fuel filter I'm the being of December. This morning I changed the distributor cap and rotor and it's still acting up. It also kills at red light randomly!
Erichl504 is offline   Reply With Quote
Old 01-21-2013, 05:02 PM   #2
slideslidegnarslide
Trader Rating: (29)
slideslidegnarslide is an unknown quantity at this point
Feedback Score: 29 reviews
Vacuum leak?
slideslidegnarslide is offline   Reply With Quote
Old 01-21-2013, 05:24 PM   #3
rwtf
rwtf's Avatar
rwtf is an unknown quantity at this point
checked spark plugs?
rwtf is offline   Reply With Quote
Old 01-21-2013, 05:30 PM   #4
unijabnx2000
unijabnx2000's Avatar
unijabnx2000 is an unknown quantity at this point
EGR?
vac leaks?
unijabnx2000 is offline   Reply With Quote
Old 01-21-2013, 07:35 PM   #5
LowLipS13
LowLipS13's Avatar
LowLipS13 is an unknown quantity at this point
check your MAF.
LowLipS13 is offline   Reply With Quote
Old 01-21-2013, 08:18 PM   #6
sidewaysonmy180
sidewaysonmy180 is an unknown quantity at this point
Ok this is what you need to do. Turn the car on and have it running. Then remove the spark plug wires. One at a time. Start with 1 then 2 etc. if u notice the motor starts jerking more. Put the wire back in. Go to the next one then next one. Until you don't see a change in the motor. If this works. This will show you witch fuel injector is failing on you. Kade injectors suck and fail often. Dont drive your car like that you'll blow motor.
StAySiDeWaYz
sidewaysonmy180 is offline   Reply With Quote
Old 01-22-2013, 12:47 AM   #7
Erichl504
sorry for the late response. iv checked everything, i also noticed my knock sensor was unpluged but is still running like crap. i ran the ecu codes and came back with
12-mass airflow sensor circuit
34-knock sensor
35-egr temp sensor
41- air intake temp sensor
82-crank shaft position sensor
i just clean the MAF and car still runs kinda like crap. it idles fine and still drives good but every now then (daily) it bucks and loses power.
as to everyone else who responded, plugs are brand new and gaped to .40, i dont have any vacuum leaks cus i can still get down on the throttle. i heard that the "coolant temp sensor" might cause the car to run crazy while cruising
Old 01-24-2013, 07:39 AM   #8
Giuseppe@EnjukuRacing
Giuseppe@EnjukuRacing's Avatar
Giuseppe@EnjukuRacing is an unknown quantity at this point
Send a message via AIM to Giuseppe@EnjukuRacing
I had a similiar problem with my old zenki, come to find out it was my fuel pump.
Giuseppe@EnjukuRacing is offline   Reply With Quote
Old 01-25-2013, 12:19 AM   #9
s13livin
s13livin's Avatar
s13livin is an unknown quantity at this point
never do that, it can damage the ignition system
out of 240s for now.510s for now. coupe again in the future.
s13livin is offline   Reply With Quote
Old 01-25-2013, 12:36 AM   #10
Nizzan4u2nv
Nizzan4u2nv's Avatar
Nizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura about
Send a message via AIM to Nizzan4u2nv
34-knock sensor
35-egr temp sensor
address these issues first. Try a different maf. Get another knock sensor and install it. If its the original sensor theres a good chance its no good. Egr temp sensor is on the intake manifold between runner number 2 and 3. Air intake temp sensor is on the airbox. Crankshaft position sensor is at the back of the motor at the top where the tranny meets the block. Is the wiring harness all in tact? Thats a lot of codes for the ecu to be throwing, seems like its been neglected severely or you have wiring issues.
Nizzan4u2nv is offline   Reply With Quote
Old 01-25-2013, 02:15 AM   #11
mantas
mantas's Avatar
mantas is an unknown quantity at this point
Just had the same issues same codes on mine. It was bad maf plug. One of the wires was dead no continuity. Car still ran like shit after i fixed it, cleared the codes and bam runs like a champ and no codes. I had a bad knock sensor too, if it has any cracks or rust replace it and move on to the next issue - your maf guarantee it. As a test rev the car at idle if it loops - revs up and down while you hold the throttle in one place then its your maf. And dont be a fucking leech, report back when you fix it or if you dont lol.
mantas is offline   Reply With Quote
