Old 04-03-2004, 01:57 PM   #1
tak-
tak-'s Avatar
tak- is a well-known jackass
Send a message via AIM to tak-
aftermarket bearings
Spun a main bearings. Do i replace with OEM, or are there aftermarket bearings?
Money is a factor, but I'd rather built it strong while its apart ya know. Suggestions please.
I am going to replace my rod bearings too.
Will the main's need to be pressed onto the crank?
thanks.
tak- is offline   Reply With Quote
Old 04-03-2004, 02:05 PM   #2
Var
Var's Avatar
Send a message via AIM to Var
umm you spun a main bearing it's possible you fucked the journal on the crankshaft. they are supposed to last till 300,000 miles the rod bearing usually goes around 200,000 or less. So if you spun a main bearing, i would just go get another block and freshen it up with new bearings. Pull it apart to see what's good and what's bad. you may find other things that are bad.
Hi
Old 04-03-2004, 02:08 PM   #3
aeontony
aeontony is an unknown quantity at this point
There are aftermarket bearings if you are talking about SRs. Some Japanese manufacturers (Tomei, etc.) have stronger bearings. Not so sure about the KA.
The main berarings don't need to be pressed onto the crank.
S14.5 for sale. Must move on with life...=(
http://www.zilvia.net/f/showthread.php?t=56822
Au no wa wakare no hajime...
aeontony is offline   Reply With Quote
Old 04-03-2004, 02:27 PM   #4
tak-
tak-'s Avatar
its a ka24de, and from what I can see, it doesnt look bad at all. I will take the crankshaft to a machine shop and have them check it out.
Old 04-03-2004, 02:59 PM   #5
Var
Var's Avatar
www.ka24de.com
email these people they know what's available and what you will need
Hi
