Old 10-08-2006, 10:46 AM   #1
TurbLu
TurbLu is making his/her stupidity well-knownTurbLu is making his/her stupidity well-knownTurbLu is making his/her stupidity well-known
Stock compression numbers for a ka24de?
Hi guys,
I know I am suppose to warm up the engine before doing a compression test, but I cant do that right now. So what kind of compression numbers should I expect for a stock Ka24de compression?
TurbLu is offline   Reply With Quote
Old 10-08-2006, 12:26 PM   #2
Indolent
Indolent's Avatar
Indolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura about
Send a message via AIM to Indolent
180ish, anything above is really good
and don't forget to have the throttle body open
Indolent is offline   Reply With Quote
Old 10-08-2006, 12:39 PM   #3
PS13 SILVIA
PS13 SILVIA is an unknown quantity at this point
Standard is 179 psi
Minimum is 151 psi
With max difference of 14psi
PS13 SILVIA is offline   Reply With Quote
Old 10-08-2006, 03:47 PM   #4
95zilvia
95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light
last time when i did mine cold
it was 200 psi across the board
95zilvia is offline   Reply With Quote
Old 10-08-2006, 04:33 PM   #5
PS13 SILVIA
Possibly something wrong with the compression tester gauge or you just have a shit load of carbon biuldup on your pistons...lol
Old 10-08-2006, 05:41 PM   #6
PITCH
PITCH's Avatar
PITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to behold
Did mine last week.
190,190,195,195
97 KA24DE 128K
I'm beleiving carbon buildup also.
PITCH is offline   Reply With Quote
Old 10-09-2006, 01:38 AM   #7
gotta240
gotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfection
190 or above equals
milled head
carbon buildup
bad tester
or maybe brand new ka with 15k. miles on it...doubt it though!
gotta240 is offline   Reply With Quote
Old 10-09-2006, 01:57 AM   #8
95zilvia
yeah i think ill check it again sometime
Old 07-20-2011, 03:34 PM   #9
eddie91
eddie91's Avatar
eddie91 is an unknown quantity at this point
i did mine today it was
175,175,188,175-_-
eddie91
eddie91 is offline   Reply With Quote
Old 07-20-2011, 04:06 PM   #10
Hashiriya415
Hashiriya415's Avatar
Trader Rating: (22)
Hashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enough
Feedback Score: 22 reviews
Cold rebuilt engine about 155, 180 when hot.
Hashiriya415 is offline   Reply With Quote
Old 08-27-2011, 05:24 PM   #11
91es13coop
91es13coop's Avatar
91es13coop is an unknown quantity at this point
90 across all 4?>?? but runs really well? what am i doing wrong
eatSleepDRIFT
91es13coop is offline   Reply With Quote
Old 08-28-2011, 01:40 PM   #12
orion::S14
orion::S14's Avatar
^^^ Engine warm? Throttle held wide open when testing? Battery fully charged? Crank over at least 3-4 times per cylinder...
...to get a good reading.
- Brian
www.KA24DEvelopment.com
Old 12-11-2011, 08:58 PM   #13
terribleibs
terribleibs is an unknown quantity at this point
Did mine todau. 195 across the board. I beleive it to be rebuilt so i am assuming milled head.
terribleibs is offline   Reply With Quote
Old 12-11-2011, 11:38 PM   #14
godrifttoday
godrifttoday's Avatar
Trader Rating: (82)
godrifttoday is an unknown quantity at this point
Feedback Score: 82 reviews
140 cold ... Fawk
NEED Bolt kits for your car?
http://i48.tinypic.com/6gx5e0.jpg
godrifttoday is offline   Reply With Quote
Old 12-12-2011, 10:56 AM   #15
OoAtreyuloO
OoAtreyuloO's Avatar
OoAtreyuloO is an unknown quantity at this point
18x across warm
OoAtreyuloO is offline   Reply With Quote
Old 12-12-2011, 11:00 AM   #16
Silverbullet
Silverbullet's Avatar
Silverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really nice
Send a message via AIM to Silverbullet
Originally Posted by godrifttoday View Post
140 cold ... Fawk
how cold is cold? The reason you do it warm is so that it is tested at a controlled temperature where the rings will be expanded to the right amount.
Your rings will be a different size at 40 degree vs 80 degree weather affecting your compression results, it may be minimal but try again when its warm.
HouseBuyers365.com
Originally Posted by Flybert
Go back to whatever Honda forum you came from.
Silverbullet is offline   Reply With Quote
Old 01-18-2012, 06:22 PM   #17
MurkyRiversS13
MurkyRiversS13's Avatar
MurkyRiversS13 is an unknown quantity at this point
Can I borrow someones carbon buildup???
I got 119, 121, 120, 121 on a warm engine.
Cap full of oil gave me 140, 170, 150, 150...... new rings are in order for this bad boy.
MurkyRiversS13 is offline   Reply With Quote
Old 01-18-2012, 06:27 PM   #18
roboticnissan
roboticnissan's Avatar
roboticnissan is making a name for him/her selfroboticnissan is making a name for him/her selfroboticnissan is making a name for him/her self
Ive got 90k miles on my motor and i get 150 on all four cold and 170 warm. For sure never been rebuilt all stock and original from the day it was built
roboticnissan is offline   Reply With Quote
Old 01-18-2012, 06:53 PM   #19
SMM
Trader Rating: (26)
SMM is an unknown quantity at this point
Feedback Score: 26 reviews
Just for you newbs.
Warm engine up.
While engine is running pull the fuel pump fuse. ( Relieves fuel pressure)
Pull all plugs.
Disconnect distributor.
Gas pedal to the floor.
Crank 3-5 times per cylinder.
Did mine on my newest s14. 160k.
210 210 210 210.......Carbon build upppp, runs like a beast though.
SMM is offline   Reply With Quote
Old 01-19-2012, 11:29 AM   #20
oneround1
oneround1 is an unknown quantity at this point
That's nice! ^ thanks for the info.
Compression I had was 190 across warm.
oneround1 is offline   Reply With Quote
Old 02-25-2012, 12:10 AM   #21
thinhthan
thinhthan is an unknown quantity at this point
i got 150. 151. 150. 130. how much oil should i pour into the hole to check to see if i need new rings?
thinhthan is offline   Reply With Quote
Old 02-25-2012, 02:39 AM   #22
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Just a oil cap full. But just looking at that 130, that shit is probably done. I'm sitting at 140-150 on mine and I'm burning oil with the HG probably on its way out.
CLICK HERE!!!
Old 02-25-2012, 07:25 AM   #23
MurkyRiversS13
Yup just an oil cap full of oil in each cylinder.
Old 02-25-2012, 12:01 PM   #24
thinhthan
a oil cap as in the quart cap or a gallon cap? my car doesnt burn oil or smoke or anything. it drives fine. the engine shakes a lil though when im at like a light. so should i do a rebuild? if so is there a rebuild kit i can buy?
Old 02-25-2012, 12:06 PM   #25
MurkyRiversS13
quart cap, definitely not the big ass cap.
Make sure you have the car turn over 7 times. remove all of the spark plugs and do one cylinder at a time withe the throttle full open. Make sure you test on a warm engine as well.
Engine shaking can be related to other things as well. Cylinder misfire and bad engine mounts. It all depends.
Im sure you can buy new rings from autozone or something if you want to do a budget rebuild. Check your cylinder walls for scoring (bad) and if you can still see the cross hatching from the honing and no scoring, you should be good with new rings.
Granted its your bottom end that is causing your low compression. Could be the head causing the problem.
Old 02-25-2012, 12:18 PM   #26
thinhthan
do all the plugs have to be removed cause all i did was take one spark plug out put in the tester. pushed gas pedal down and cranked it like 3 time each time like 4 secs and i did it one cylinder at a time with all the other plugs in. would that make a differences if the other plugs are still in? i drove the car to the store before i checked it so it was warm. and when i put the oil in the cylinder with 130 it only raised it like prob by 5 psi so now im guessing its my lifters? that has a problem
Old 02-25-2012, 12:27 PM   #27
MurkyRiversS13
Yea all other plugs should be out. It will make it easier for the test and better result. You unplug the injectors right?
You should do about 7 turns not 3-4. You'll hear the compression stroke when turning the car over.
Old 02-25-2012, 01:45 PM   #28
thinhthan
how do i hear the compression stroke? and how do i know its 7 turns? i didnt unplug the injectors i just pulled out the fuel pump fuse and started it until it died than i unplug the distributor
Old 02-25-2012, 02:01 PM   #29
MurkyRiversS13
The way you do it is the right way. When you start the test you'll be able to hear the compression stroke trust me.
Old 02-25-2012, 02:04 PM   #30
thinhthan
and i had a question. sometimes when im doing the test ill hear a pop. is that something i should worry about?
