Old 04-25-2013, 05:24 PM   #1
Cellz
Cellz is an unknown quantity at this point
SR New sr20 owner with dumb sparkplug question
Im new to owning a redtop sr20det and doing my first round of preventive maintenance on it. I wanted to see what condition the spark plugs were in what type and what gap. I unscrewed the top part and took out the thing that goes down to the sparkplug, i think that is the coil pack?, and its covered in oil, is that normal? Or is there a blow seal?
I didnt take the spark plug out yet, i just took off the part that connects from the spark plug wire to plug (coil pack?). Once i saw it covered and dripping of oil i got scurd and put it right back in and back on, lol. I expected the chamber to be clean. I'm a total newb and just wanna make sure that its ok before i proceed forward!
Cellz is offline   Reply With Quote
Old 04-25-2013, 05:28 PM   #2
PureRush
PureRush is an unknown quantity at this point
Your valve cover gasket is leaking oil in the spark plug hole. The oil in there can cause issues with ignition and you need to replace that gasket. It's really simple to fix.
PureRush is offline   Reply With Quote
Old 04-25-2013, 05:47 PM   #3
Cellz
That's what i expected. Anything i need to know and where is a good place to order from?
Old 04-25-2013, 05:48 PM   #4
rwtf
rwtf's Avatar
rwtf is an unknown quantity at this point
just sell your car. please.
rwtf is offline   Reply With Quote
Old 04-25-2013, 05:49 PM   #5
nekrodev
nekrodev's Avatar
nekrodev is an unknown quantity at this point
OEM Valve Cover Gasket - Nissan SR20DET - Enjuku Racing Parts, LLC
"To be or not to be" - there is no such question. To be! But to be what...?
nekrodev is offline   Reply With Quote
Old 04-25-2013, 05:51 PM   #6
Cellz
would this do fine? Nissan Genuine OEM S13 SR20DET Valve Cover Gasket
The sr has a t28 turbo and is at 20psi, i would think maybe there would be a better one than OEM
Old 04-25-2013, 05:53 PM   #7
Cellz
i know i know i know! was an epic dumb question, just not familiar with SRs yet. Had a KA all my life
Old 04-25-2013, 06:16 PM   #8
Hoffman5982
Hoffman5982's Avatar
Trader Rating: (25)
Hoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really nice
Feedback Score: 25 reviews
Uhh what??
Hoffman5982 is offline   Reply With Quote
Old 04-25-2013, 06:22 PM   #9
litch
litch's Avatar
litch is an unknown quantity at this point
Just out of curiosity... when you aren't on the throttle, and you are - on your boost gauge... what number does it read?
The reason I ask is I will bet that you are reading 15-12 on the negative side... hence why you are "boosting" up to 20psi..
I would venture to guess that you have a leak sir.
litch is offline   Reply With Quote
Old 04-25-2013, 06:25 PM   #10
Cellz
Originally Posted by Hoffman5982 View Post
Uhh what??
T28 s15 Dbb turbo, and is pushing 20 psi form what the gauge is reading. It has a Greddy Profec b spec 2 boost controller as well, and i put it back to default settings but still pushing 20... drives fine and all but im not really triyng to make it boost at all until i get it all figured out and working properly
Old 04-25-2013, 06:38 PM   #11
Cellz
when im not on the throttle its around negative 4 or so, a leak is very possible, the kid i got it from dogged it out pretty bad
Old 04-25-2013, 06:41 PM   #12
litch
litch's Avatar
I would bet something very close to the inside of my right leg... you have a leak... and since you said he dogged it out... here is another question for you...
is the car lowered?
does the car have a fmic?
if the answers to both these questions is "yes"... I bet you will find the leak on the intercooler/couplings/piping right up front... you are supposed to be at -20 with no leaks mang.
Old 04-25-2013, 06:45 PM   #13
jamg
jamg is an unknown quantity at this point
spark plug gaskets.
i can sell you the 5 that you need. $10 shipped.
jamg is offline   Reply With Quote
Old 04-25-2013, 06:51 PM   #14
Cellz
is the car lowered?
Yes and yes! Thank for this advice
Old 04-25-2013, 06:51 PM   #15
zombiewolf513
zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513
Im curious about this car. Did you recently buy it with the swap already done? The s15 t28 isnt efficient past about 18psi, so youre doing more harm than good running it to 20, if that really is the case. And since the profec's default settings are about 14.5 psi with average "gain" and "set gain" I have a sneaky suspicion youre going WOT in first gear and spiking like a motherfucker.
Change out the valve cover gaskets.
BTW, what else does it have on it if youre effectively maxing out the boost on a t28?
zombiewolf513 is offline   Reply With Quote
Old 04-25-2013, 06:53 PM   #16
Cellz
Originally Posted by jamg View Post
spark plug gaskets.
well i havent taken off the plug to see if they are oil fouled yet, so i dunno quite yet if i will need them, but i wont be surprised if i do need em
Old 04-25-2013, 06:55 PM   #17
litch
litch's Avatar
I bet he isn't actually boosting to 20, I bet he is getting to about 12 psi but has a bad leak and he doesn't have the correct vacuum... since his gauge is missing 16ish on the negative side...
his gauge is lying to him telling him he is getting madawesomesuperboostyo... when he is only getting stock boost...with a nasty leak... which means his car just smells like gas...
Old 04-25-2013, 06:57 PM   #18
litch
litch's Avatar
you just said the guy before you dogged it out... Just assume everything that is non-durable/blowable is fucked. Change the oil, get new coolant, change out the gaskets, change the spark plugs, fix the turbo leak, go to a reputable shop and have them compression test your engine... then drive it around confident that you have paid for your sins.
Old 04-25-2013, 06:57 PM   #19
PureRush
I dont think you understand. Oil fouled spark plugs are cause by bad rings in the cylinder. The oil thats in the sparkplug hole is coming from the valvecover. Regardless of the condition of what the spark plug tips look like, you will need to replace the valvecover gaskets or else you'll have ignition failure for that specific cylinder.
Old 04-25-2013, 07:09 PM   #20
Cellz
port and polished head, 550cc injectors, T28 s15 turbo, Profec b spec 2 BC, turbonectics exhaust system, Mishimoto radiator, Greddy Dual FMIC, 3" exhaust, Greddy Downpipe, GReddy BOV, has a chipped ECU, cant remmeber the name or where it was from, has some other stuff i cant think of. My statement of the car running fine wasnt was not implying its boosting properly, cuz its not, and i havent tried to push it too boost enough to get a good read on the gauges during boost to see it spike. i havent actually gone WOT, the times i have pushed it it was more of a gradual push past 4500 rpms, i did it enough to see the gauge hit 20, and i thought the default setting would of had it at around 8 or something
Old 04-25-2013, 07:12 PM   #21
Cellz
Right, i understood the part that the valve cover gasket is in need of replacement, just not aware of the plug rings needing replacement. But if you guys say they need to be it will be done
Old 04-25-2013, 07:45 PM   #22
Cellz
does not smell like gas that is for sure, the rest is very true lol
Old 04-25-2013, 07:50 PM   #23
ultimateirving
ultimateirving's Avatar
Cellz, the spark plug gaskets are what go between the valve cover and the head to keep oil out of the spark plug galleys.
When you pull off the valve cover you will see the 5 O gaskets.
Z32 with lq4 swap
Old 04-25-2013, 07:54 PM   #24
Cellz
Yup that's the plan.
Old 04-25-2013, 07:58 PM   #25
Cellz
ohhhhh i get it now, for some reason i was thinking the were around the plugs themselves, and not the top of the galleys. So then that the spark plug gaskets are the only replacement needed, and not the valve cover gasket or just go ahead and do both?
Old 04-25-2013, 08:12 PM   #26
zombiewolf513
Couldnt hurt to do both
Old 04-25-2013, 08:21 PM   #27
Cellz
yeah both is gonna be the way i go. valve cover gaskets are easy money, anything to know about doing the plug gaskets? I assume some grey RTV or something wont hurt right?
Old 04-25-2013, 08:27 PM   #28
Cellz
i see what you mean, piston rings and/or valve seals will cause oil fouled plug tips, my bad
Old 04-25-2013, 08:29 PM   #29
zombiewolf513
You dont need rtv except for around the half circle cutouts on the front and back of the head on the s13 sr, i have always used the red for that with success. Just look at the fsm for valve cover installation procedure and follow that. Easy
Old 04-25-2013, 08:42 PM   #30
Cellz
Thanks everyone, and thank you for not flaming me like crazy!
