Old 09-15-2007, 01:13 AM   #1
DARKEST_HOUR
DARKEST_HOUR can only hope to improve
s14 BEE*R Rev limiter/KA24DE ???
*searched
Anyone successfully install the Bee* R rev limiter into there obdII KA ??
Can't get mine to work
I went by ritz_s14 instructions of
"For those of you who ever plan to install a BEE*R Rev limiter on your s14
Red is ignition
Black is ground
White(optional)-ebrake switch
4Cyl = Cut Grey Wire
Rotary Engines: Cut Brown Wire
6Cyl = leave all wires intact.
Yellow-pin 44/40 is your reference signal(1degree)
Green-41/45 is your 180degree signal."
it didn't work
help !
DARKEST_HOUR is offline   Reply With Quote
Old 09-15-2007, 04:10 AM   #2
illvialuver
illvialuver's Avatar
no i havent but i want one for mine, so ill check back to see when you get this finished
Old 09-17-2007, 10:21 PM   #3
DARKEST_HOUR
So anyone if the rev limiter worked for ritz_s14.I sent him a few messages . . . no reply
Old 02-22-2013, 03:12 AM   #4
Paint209
Paint209 is an unknown quantity at this point
back from the dead. anyone?
Paint209 is offline   Reply With Quote
Old 05-12-2013, 03:19 AM   #5
cparcell
cparcell is an unknown quantity at this point
It's easy use pin 38 ac/power blk/red stripe with red wire beer, pin 39 blk with blk beer which is ground, pin 40 with yellow wire and pin 41 with green wire. This works for a 95 ka24de manual Trans. Male sure beer is on 1-10 gain and rev limit on 4k to test
cparcell is offline   Reply With Quote
