S14 SR20 help! Over fueling
Well I've done lots of searching and trouble shooting for months now and can't seem to get this car running smoothly again.
I have freshly rebuilt the top end of my sr20. List of upgrades after rebuild: S14 sr20det Hks step 1 256 cams 740cc injectors Z32 maf Rs enthalpy tune I can't figure out what else is wrong so please help me on this one. Car idles normally but sounds like its missing a couple times a minute. When I go to rev the car, it sounds like it being over flooded with gas. But if I keep revving it, the excess gas seems to get burned out and I can rev the car like its running perfectly. But once I let it go back to idle and try revving it again, it starts to bog again. Spark plugs are fouled and black smoke coming out the exhaust. List of things I have checked: Compression- 150psi across all four Timing- set to 15* Checked for vacuum and boost leaks Changed out mafs with another z32 Maf wiring should be correct and I can rev it throughout the whole rev range Last thing to check is the injector o-rings. Would leaking o-rings cause this though? The car starts up fine and idles nicely, just has a hard time revving it up. Martin at enthalpy has been helping me out a lot but I need to get this car running asap. It ran perfectly before the rebuild but after is when all of this started happening. PLEASE HELP, this is my daily |
Tags |
new injectors, new tune, running rich, sr20det |
