Old 10-18-2012, 01:10 PM   #1
mantas
mantas's Avatar
mantas is an unknown quantity at this point
OBX RB25DET Turbo Elbow fitment
Well this is not a question just a statement perhaps. I hope this helps out some other fellow rb owners who have steering column fitment problems when doing the rb to s14 swap.
I have my engine (rb25det) mounted on an r33 crossmember into an s14. I had the typical column clearance issues and ended up grinding down the stock elbow. Due to a major leak at the flange i had to change my elbow and got the obx ebay elbow. It has about 1/2" of clearance from the steering column but i did have to widen some of the holes to make this thing align. Hope this helps anyone that needs info on these elbows. I searched for hours and didnt find any input on the fitment or performance of these things. I know the other ebay elbows do not fit and need mods but this thing is like a glow minus the holes lol. If anyone needs more info pm or post here.
Untitled by onedolla99cents, on Flickr
mantas is offline   Reply With Quote
Old 12-19-2012, 07:38 PM   #2
xlarry
xlarry is an unknown quantity at this point
Thanks really needed this!
xlarry is offline   Reply With Quote
Old 12-19-2012, 10:12 PM   #3
mantas
mantas's Avatar
Thats exactly why i made the post. I even have pix to post up which ill do when i jump on the computer tonight.
Old 12-19-2012, 10:52 PM   #4
mantas
mantas's Avatar
Pix posted, i know the fitment pix don't do it justice but its about 1/2" or more clearance.
Old 12-19-2012, 11:17 PM   #5
PrimeDirective
PrimeDirective's Avatar
PrimeDirective is an unknown quantity at this point
What mounts are you using? Stock?
PrimeDirective is offline   Reply With Quote
Old 12-19-2012, 11:36 PM   #6
mantas
mantas's Avatar
Stock r33 mounts with r33 crosmember from what i recall. I think s14 and r33 mounts are very similar.
Old 08-16-2013, 06:12 PM   #7
BoredEE
BoredEE is an unknown quantity at this point
Your mileage may very with this elbow.
For starters the elbow isn't a drop in replacement. Or at least mine isn't.
Also the elbow doesn't even come close to fitting around the steering shaft.
This is a "OBX" version not the non-OBX version on ebay.
But who knows maybe they just copied the "OBX" plate.
My setup is S14, RB25DET with R33 crossmember and nismo motor mounts
I purchased it from:
Super Saver Accessories Home Page
And of course they want a 25% restocking fee.
BoredEE is offline   Reply With Quote
Old 08-17-2013, 12:17 AM   #8
mantas
mantas's Avatar
Mine was the ebay version. I do recall having issues aligning it but mine cleared the steering rack way better than stock. Did you snap any fitment pix?
Old 08-17-2013, 12:30 AM   #9
Edwin562
Edwin562's Avatar
Are you planning to wrap the elbow?
Old 08-17-2013, 04:58 AM   #10
soundboy
soundboy is an unknown quantity at this point
He should ^
Sent from my GT-P3110 using Tapatalk 4
soundboy is offline   Reply With Quote
Old 08-17-2013, 08:09 AM   #11
BoredEE
I can't get the elbow even on, the wastegate pipe is hitting the steering shaft.
It looks like even if I shorten the wastegate pipe I'll still have interference with the main pipe, that'll need to be dented to clear the shaft.
Old 08-17-2013, 12:02 PM   #12
mantas
mantas's Avatar
Odd. May be yours is slightly different because of the mounts or the elbow itself is fucked up. Someone pm'ed me a while back asking about the elbow fitment, the person got the ebay one and said it worked, so i dont know what to tell you but that sucks balls that it does not fit.
Old 08-17-2013, 12:05 PM   #13
mantas
mantas's Avatar
Is the dp bolted to the elbow in that pic?
Old 08-17-2013, 01:15 PM   #14
BoredEE
The elbow is just hanging on the bottom turbo studs, the DP isn't installed.
Old 08-17-2013, 09:16 PM   #15
mantas
mantas's Avatar
Shit idk what to tell yah might be the nismo mounts since last i checked they make the engine sit lower or higher, but obviously it would be easier to get some other solution for the elbow than running different mounts.
Old 08-18-2013, 06:49 PM   #16
BoredEE
What type of brackets do you have?
Mine are these type:
With a round engine mount
or
The square type engine mount
