Old 05-06-2004, 11:21 PM   #1
formeRiceR
formeRiceR is an unknown quantity at this point
NA bolt-on estimates ...
okay after days of thinking I've decided that I'm going to limit my spending on my project (AKA NO TURBO). With college loans kicking in in like a couple of months and my summer trip to Japan and Korea, I need to stop spending money.
I'm wondering what kind of figures I would be putting down with the following mods:
Short Air Intake
OBX SS headers
SAFC
Pullies (maybe)
PDM cams
Electric Fan
70mm JIC exhaust
Centerforce Clutch ( I know it doesn't add HP )
Also is there anything I can do to squeeze out some more power. I Just want something that would be fun to drive around in. 200 hp is unrealistic N/A.
"Street racers don't need girls." -Lonely Driver
Learning about cars one FLAME at a time ... (thanks to TNORD)
formeRiceR is offline   Reply With Quote
Old 05-06-2004, 11:27 PM   #2
sticky240
sticky240's Avatar
sticky240 is an unknown quantity at this point
im sorry if this is a retarded noob question, but what does/can you do with a SAFC (Air/Fuel controller right)?
Guh-Noo-Beez
sticky240 is offline   Reply With Quote
Old 05-06-2004, 11:30 PM   #3
formeRiceR
correct de mundo...
yeah my question is a noob question too...
Old 05-06-2004, 11:34 PM   #4
ICKY
Account Closed
ICKY is an unknown quantity at this point
Send a message via AIM to ICKY
exhaust+headers+intake, my brother clocked a high 14 in his S14. more like an air filter than an intake tho...
ICKY is offline   Reply With Quote
Old 05-06-2004, 11:39 PM   #5
HyperTek
bring you up to a whooping 155hp!!!! hehe jk. But I wouldnt be surprised, probably just better throttle response. Since cars loose alot over age, wear and tear, and drivetrain.
Keep it Classy
Old 05-07-2004, 12:04 AM   #6
zombieman
zombieman is an unknown quantity at this point
you can raise your hp and torque
zombieman is offline   Reply With Quote
Old 05-07-2004, 02:53 AM   #7
sticky240
sticky240's Avatar
umm, you mean like across the rpm range? Like instead of peaking at like 4500 you can set it to peak at around 4000?
Guh-Noo-Beez
Old 05-07-2004, 04:53 AM   #8
Colorado S14
Colorado S14 is on the path to ruinColorado S14 is on the path to ruin
The S-AFC allows you to adjust the air flow meter signal before the ECU. The ECU then reads the adjusted signal and adjusts fuel accordingly. This allows you to modify the signal to obtain the proper ration of air to fuel. It will add power if tuned correctly, but on a NA 240sx it wil most likely only give maybe 3-5 HP, turbo cars however can see gains of 10-50+ depending on how bad the mixture was before. The biggest diference that I noticed on my car with it was that the engine ran smoother, not a whole ton of extra power.
Colorado S14 is offline   Reply With Quote
Old 05-07-2004, 09:49 AM   #9
sykikchimp
WOW addicted
sykikchimp's Avatar
I would guess about 160whp. That's about average for I/H/E/cams, and pullies.
Old 05-07-2004, 09:51 AM   #10
Var
Var's Avatar
Send a message via AIM to Var
for the price of the Safc plus 100 bucks you can buy higher compression pistons which @ 10.5:1 compared to stock 8.5:1 should give you like 30 horses to the wheels, and you can bore it out while you're there. Better investment IMO that the SAFC cause you wont need it. People run 200 horse n/a ka's with stock injectors. all you would need is a fuel pump. And i'm guessing the Jic exhaust is way over 500 bucks.. To be more cost effecient buy used intake/exhaust. IMO these are overpriced when brand new.
Hi
Old 05-07-2004, 09:56 AM   #11
sykikchimp
WOW addicted
sykikchimp's Avatar
fuel pump is not necessary.
and proper fuel tuning on a KA with those mods will give more than 3-5 hp. more like ~10. I know a guy that got 12 whp when he added a JWT NA ECU with Cams intake exhaust, and underdrive crank pulley already installed.
Old 05-07-2004, 09:59 AM   #12
Var
Var's Avatar
i was talking about the 200 horswepower guys. But you're probably right. I asked Bill Gude who builds those kits for Ka's and i think he said stock fuel system is ok.
Hi
Old 05-07-2004, 10:53 AM   #13
Nismo240SX
Nismo240SX's Avatar
Nismo240SX is on a distinguished road
Send a message via AIM to Nismo240SX
get everything you mentioned plus a test pipe, and a lsd. With those mods, it will be a simple, but yet fun n/a car.
1990 Nissan 240sx:s13 blacktop, s13.5 front
Nismo240SX is offline   Reply With Quote
Old 05-07-2004, 12:15 PM   #14
pruto
pruto's Avatar
pruto is a name known to allpruto is a name known to allpruto is a name known to allpruto is a name known to allpruto is a name known to allpruto is a name known to allpruto is a name known to allpruto is a name known to allpruto is a name known to allpruto is a name known to allpruto is a name known to all
i dunno man... stock KA with lsd is a simple, yet fun n/a car...
with all that money, save up for suspension or a turbo kit, the HP per capita you will be getting is WEAK for any of the NA mods. why bother?
Paul
Black and Red
pruto is offline   Reply With Quote
Old 05-07-2004, 12:51 PM   #15
95Blue240sx
95Blue240sx's Avatar
95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection
^^^^ werd. the only think i have on my car for "perfomance" is a aem intake. i wend full suspension with a vlsd(sucks) but still fun for me.
Please leave me feedback
95Blue240sx is offline   Reply With Quote
Old 05-07-2004, 04:09 PM   #16
formeRiceR
already have a VLSD and my suspension is pretty good:
HKS HyperMax-II
Nismo Power Brace
Touge Factory T/C rods
F/R Strut Bar
300zx w/ Project Mu Pads
Thinking about getting sway bars but I hardly have any sway with my current setup.
Just need to get a little more power. Not askinf for too much...
Old 05-07-2004, 04:55 PM   #17
mike13
mike13's Avatar
mike13 is an unknown quantity at this point
Send a message via AIM to mike13
in my opinion those mods are a waste of money that wont give you results you are looking for.
Unless you gain 50 hp, dont even get out the checkbook. just my opinion on beginning to mod an engine.
mike13 is offline   Reply With Quote
Old 05-08-2004, 10:38 AM   #18
mellojoe
mellojoe is an unknown quantity at this point
If you've got a pretty good suspension, then you've done all you should with the stock KA. Go for the intake/exhast and be done.
mellojoe is offline   Reply With Quote
Old 05-08-2004, 12:48 PM   #19
nightwalker
nightwalker's Avatar
nightwalker is an unknown quantity at this point
I like the response you get with NA. Especially if you want to auto-x, or like to do touge. My plans for NA building (taken from my crazy NA Honda days)...
shorter intake on passenger side, HKS filter
headers
3 inch exhaust
test pipe
pullies
MSD ignition
extrude hone intake manifold
port matched and enlarged throttle body
some KA24E pistons
lightening up the car (A LOT)
NGK plugs and wires
cams... not sure of yet
JWT ECU
I estimate somewhere around 180 ish to the wheels. Right now, all I have is an exhaust, msd, and HKS filter on factory pipe, and the car is fun. You should see the look on the SR guys faces when they can't pull away from me on the touge, or when my drifting looks better.
In life, we often cast the line of hope fishing for the best possible opportunity. Sometimes with enough effort, the things we catch are nothing short of amazing.
nightwalker is offline   Reply With Quote
Old 05-08-2004, 01:03 PM   #20
Chernobyl
Chernobyl's Avatar
Chernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond repute
raise the compression, cam the crap out of it, and put two weber DCOE 44's on it (carbs, for those who dont know).
Thats the only way you'll make a noticeable amount of power with a KA.
Believe me, I drive a stock KA and have driven two that had all the bolt ons you mentioned (plus or minus one, i dont remember the details). My car felt no slower than those two I drove.
I did like the lighweight flywheel in one of those cars... that's a fun investment.
Chernobyl is offline   Reply With Quote
Old 05-08-2004, 01:27 PM   #21
Nismo240SX
Nismo240SX's Avatar
... about the previous post... i drive ka for now, but highly doubtful you keep up with them.
Old 05-08-2004, 01:54 PM   #22
Chernobyl
Chernobyl's Avatar
and who cares if I dont? they still FEEL slow. and you'd be stupid to waste money to make your car feel no faster (read no more fun)
Old 05-08-2004, 02:27 PM   #23
citizen
citizen's Avatar
citizen is making a name for him/her selfcitizen is making a name for him/her selfcitizen is making a name for him/her self
Send a message via AIM to citizen
Whats maximum safe CR on 91 octane? Would the 11.1:1 cr from the ka24e pistons be ok?
citizen is offline   Reply With Quote
Old 05-08-2004, 02:38 PM   #24
nightwalker
I'm sure your butt dynos are all very accurate. There are factory cars running 10.5 compression. 11.0 is nothing but pinging.
A side note, NA power is pretty dependant on upkeep with the car. If you don't keep it tuned, all the parts are not going to make the power they're supposed to. for instance, on the KAs, if your coolant temp sensor is not working well, it can cause you to lose 10hp at the wheels.
I like NA for a couple reasons, maintenance ease, heat, longevity, durability, margin of error (tunining)
Old 05-08-2004, 06:14 PM   #25
S14DB
AFC #1
S14DB's Avatar
Don't pay any mind to the turbo nazis. I would start with the exhaust cause you'll get gains in power, sound and, style. I would go with the Injen cold air set up. I drove around for 6 months with the short ram and added the CAE for the summer and noticed a deff. kick in the pants(low end). I have the OBX SS header in and it is great. It will make your car sound lower and louder. Everyone I know seems to like the lower tone but it rings a bit when it's cold in the cabin. Once it gets warmed up it's sweet. I have ordered the ASP pulley and will see how that goes.
Old 05-08-2004, 06:34 PM   #26
formeRiceR
yeah I got a another question for you guys....
I was running the car decently hard last night, and I had 2 people in the car with me, and all of the sudden the CEL comes on, I pulled the code last night and it said that it was the detonation sensor....and athe crank angle sensor. I've never had a check engine light on the car and I've pushed it on many different occasions ... my question is .... how can I prevent detonation?
Old 05-08-2004, 07:07 PM   #27
hurleyboi514
hurleyboi514 is a well-known jackass
Send a message via AIM to hurleyboi514
id really like to throw a set of carbs on a KA... them some cams and sohc pistons... mmm... that'd be fun...
HighTach Motorsports
hurleyboi514 is offline   Reply With Quote
Old 05-09-2004, 12:22 PM   #28
Propagandhi41
Propagandhi41's Avatar
Propagandhi41 is an unknown quantity at this point
Send a message via AIM to Propagandhi41
why sohc pistons?
Propagandhi41 is offline   Reply With Quote
Old 05-09-2004, 12:50 PM   #29
NervGS
NervGS's Avatar
NervGS has a brilliant futureNervGS has a brilliant futureNervGS has a brilliant futureNervGS has a brilliant futureNervGS has a brilliant futureNervGS has a brilliant futureNervGS has a brilliant futureNervGS has a brilliant futureNervGS has a brilliant futureNervGS has a brilliant futureNervGS has a brilliant future
Send a message via AIM to NervGS
Rebello.
-glenn
NervGS is offline   Reply With Quote
Old 05-09-2004, 01:07 PM   #30
Phlip
Yes, I look like that
Phlip's Avatar
Originally Posted by Propagandhi41
why sohc pistons?
Higher compression
Weirdo
And I write too!
