![]() S13 with Silvia front end conversion. Triple Projector Headlights.
So none of my headlights work. (High beams, low beams, fog lights). The turn signals work, but the actual headlights don't. The switch inside turns the gauge cluster backlight on, but not the headlights. I have HIDs in the low beams, but the highs and fog lights are OEM. Any ideas of what it could be? |
Is it these ones?
I just checked them and neither of them is blown. Must be a ground, right? I don't think all of the bulbs would suddenly just crap out on me. |
#6 | |
![]() Join Date: Jun 2011
also if you have a volt meter just check the bulbs/ wires and see if they are getting power or not. |
I'll check tomorrow, but I just turned them on and the drivers side fog light comes on now, but not the low beam (Just dead HID ballasts I think) and the driver's side high beam comes on. So none on the right side, and the low beam on the driver's side aren't working.
OK I used a multimeter and on the passenger's side, neither the high beam or the fog light is getting 12v, but the driver's side is fine. Need some help!
Figured this out. Took the switch apart and mirror polished all the contacts with my Dremel. Then flexed the metal tabs on the inside a bit so they're all making good a good connection and presto! All lights are working again and are brighter.
Money spent....$0.00 Time spent....30-40 minutes Cruising around a boosted s13 while enjoying working projectors...priceless ![]() |
#12 | |
