Old 09-30-2013, 06:07 AM   #1
mattysr20
mattysr20 is an unknown quantity at this point
drive shaft noise
ok so while I was changing my breaks I noticed when I rolled the car back and forth their was a noise that sounded like something hitting the muffler so I crawled under the car and rolled it back and forth and it seems to be coming from where the drive shaft enters the diff it also does it when I'm taking off like something is loose.
Anyone had this issue before? or know what it might be? I don't wanna mess other stuff up.
95 240 with aluminium drive shaft
Posted from Zilvia.net App for Android
mattysr20 is offline   Reply With Quote
Old 09-30-2013, 06:27 AM   #2
Mikester
Mikester's Avatar
Aluminum driveshaft is going to make some noises that sound pretty weird because there is no longer a dampener (hanger bearing/bushing) in the system... pretty much a solid line between the tranny & diff. If you also have solid or urethane bushings, rods, arms etc... you will notice it even more.
Old 09-30-2013, 07:09 AM   #3
mattysr20
im gonna get under it in a few to check everything out and make sure shit is tight
Old 09-30-2013, 09:04 AM   #4
mattysr20
well looks like the bolts were loose wow that could have been bad
Old 09-30-2013, 09:21 AM   #5
guitaraholic
guitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of light
I have an AL driveshaft, It use to make noise,, could not for the life of me find out what it was. Found out later, the E-Brake cables were rubbing on the shaft, once the rubber wore off, the metal clinked against it and made noise, try feeling underneath the driveshaft see if anything is hitting it.
guitaraholic is offline   Reply With Quote
Old 09-30-2013, 09:58 AM   #6
Mikester
Mikester's Avatar
LMAO yea loose bolts is not a good thing
Every so often, it's good to get under there & make sure everything is tight... especially after adding new pieces as they sometimes require re-seating.
Old 10-02-2013, 11:51 AM   #7
mattysr20
well I tightened the bolts but my car still makes a loud humming noise while im driving. It usually goes away at higher speeds it is extremely annoying . the car shifts fine and drives fine. I also noticed the diff was leaking a little around the plug could that be making the noise? or is my tranny about to go? could it be alignment issues? tires not balanced? wheel bearing?
Old 10-02-2013, 12:44 PM   #8
94_240sx
94_240sx is on a distinguished road
Maybe your driveshaft needs to be balanced?
courtesyparts.com
94_240sx is offline   Reply With Quote
Old 10-02-2013, 12:54 PM   #9
Hiighboost2
Hiighboost2's Avatar
Trader Rating: (32)
Hiighboost2 is an unknown quantity at this point
Feedback Score: 32 reviews
Send a message via AIM to Hiighboost2
Sounds like its ur diff making the noise.
Instagram @hiighboost @iasperformance
Hiighboost2 is offline   Reply With Quote
Old 10-02-2013, 07:43 PM   #10
mattysr20
my drive shaft was balanced when it was installed by the shop.. I was thinking the diff cause it was leaking and its welded so ill change the fluid and see what happens
Old 10-02-2013, 09:06 PM   #11
eye-5
eye-5's Avatar
eye-5 is an unknown quantity at this point
If it is a driveshaft shop AL one, It is common for them to make noise.
eye-5 is offline   Reply With Quote
