Ultimate rb26/30 part out Tomei, Nitto, 6Boost, Greddy, Hks..
Im parting out my car and here are most of the engine components I was planning on using, im slightly negotiable on pricing so offer up. I also have more parts coming as well as a widebody zenki s14 shell with version select, origin, dmax, and other quality parts. Thanks
-Rb30 series 1 block with micropolished crank this block is ready to go just needs a hone- $1500 Sorry no pics right now the motor is at Total Engine Concepts and I can get pictures for seriously interested parties -Brand New nitto I beam rb30 rods these are some of the best rods you can get for the rb30. looking for $1050 ![]() ![]() -Tomei Oil pump roughly 3k miles gear looks new asking 1200 ![]() ![]() -n1 water pump same mileage and condition as the oil pump asking 125 ![]() ![]() -r32/33 CAS with bracket -$60 ![]() RIPS brand new 7qt oil pan with extended pickup asking $600 ![]() RIPS larger crank collar $50 and RIPS head return system- $175 ![]() ![]() Brand new rb25 ARP head and main studs- $125 for the heads studs, $150 for the mains ![]() RB26 R34 Head this head has a 5 angle valve job with oem valves, new Tomei exhaust valve guides, clearanced for high lift cams, and ported exhaust hump knife edged port divider. looking for 1100. ![]() ![]() ![]() ![]() 6boost forward facing manifold T4 flange with a 60mm v band wastegate flange looking for 1100 ![]() HKS GT1 60mm wastegate with ss vacuum lines, dump tube, and extra blue spring - $300 ![]() ![]() Brand new greddy exhaust and intake cam gears $300 ![]() Brand new greddy fuel rail with fittings and hardware-$240 ![]() Brand new Yellow Jacket coil packs for r32/33 $400 ![]() Brand new Borg Warner s366 extended tip light surface rust on exhaust housing and front bolt- $550 ![]() Custom 4" down pipe and 4" exhaust came off a r33 rb26 $ 600 pics of piping and can later ![]() Flex a lite fans $250 Koyo radiator- $200 ![]() ![]() r34 polished valve covers and center piece with greddy clear timing cover $600 ![]() Brand new Ross metal jacket damper for rb25/30- $575 ![]() Tomei 87mm 1.2 thick headgasket for rb26 brand new - $240 ![]() Greddy 3 row 4" intercooler off a supra fresh polish- $850 ![]() ![]() r34 nismo white face 11k cluster $600 ![]() Brand new rb idler and tensioner pulley -$55 for both oem rb oil filter $10 ![]() rb26 intake plenum with itbs needs gaskets and hardware $250 ![]() Tilton OTII Clutch mated to an oem rb26 machined flywheel needs discs -$450 ![]() ![]() Setrab oil cooler set up with hks thermostatic oil relocator, ss lines, and aeroquip fittings, needs screw on piece for oil tree or block off if using with an sr20 $400 ![]() ![]() ![]() ![]() Lastly is a low mileage good condition rb25 transmission just needs a slave no pics yet $800 |
