Willwood BBK for s14's
Anyone know why they only offer a 4 piston kit for s14's but Honda Civics have both 4 and 6? a Mid 90's eg Hatch or Coupe wieghs far less than an s14 and less likely to fade. is it because they aare fwd and have the Transaxle in the engine bay?
![]() Join Date: Jul 2007
Trader Rating: (106)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 106 reviews
It'e because Honduh guys suck ass and think that more pistons = more stopping power. A 4-piston caliper is plenty and the amount of stopping power has NOTHING to do with how many pistons the caliper has. Why do you want 6-piston calipers anyways? So you could be rad and tell all your homies about them???
No, because my z32 calipers with 12.75 two peice rotors, hawk pads and super blue fade with my 650 lbs 2jz and Borg warner S366. and thats just stopping on the drag strip. Im a little nervous about taking the car to Sebring and putting it on the track for a 20 minute session. even on the street the stopping power isnt impressive.
Im not concerned about Piston count for aesthetics at all! I Just need the car to stop. my buddy who is getting me into road racing has an m3 and had to upgrade to a custom Porsche Brake System. as his stock m3 calpiers with hawk pads and SuperBlue wasnt cutting it. I simply asked about the piston count to find out if anyone had an idea behind their reasoning. if I cared about bling I wouldnt be posting in tech. |
Less to do with piston count, more to do with piston size, and stagger. Also, Pad choice and torque
Recommendation: Get rid of the 300ZX calipers, grab a set of 4 or 6 spot superlite (cheap enough and pad choice is abundant) and use some proper pads. I have a feeling your pad choice is lacking in the higher bite compund What pad compound are you running?? P.S racepar1, stop being a dick. Simple question the gentleman asked |
Thanks, RalliartRSX, what do you consider to be "good pads"? I am running Hawk HP Plus. first i had a custom setup using the rotors from a 350z track. now those rotrs were 22 lbs each, I thought maybe thats why the car didnt stop, so I upgraded to AMS two peice rotors where were like 10 lbs lighter on each side. then got 7.5" wide fn01rc's that were also about 10 lbs lighter per side. and even with a total of 40 lbs of unsprung weight reduction, the car still doesnt stop. so I know the z32 calipers cant work with a JZ engine up front. at least not with Hawk HP's.
I dont mind changing to a bigger wheel if I need a rotor with more surface area. I just need to know what to get. EDIT- Also changed tires, Im not near the car now and cant remember, but it is a sticky tire, it was recommeded by another road race buddy. |
#6 | |
![]() Join Date: Sep 2004
![]() There was a thread on this years ago and someone argued that the 6 piston offered a more feedback oriented bite rather than an abrupt stop like the 4 piston kit. Either or, I have the 4 piston. I would like a rear option that doesn't require switching to a Z rear brake setup, however it is more expensive than the front brake setup. |
#7 | ||
What Hawk pass are you running? HPS, HP+, Blues, Blacks... I would ditch the Super Blue and go with Brembo LCF600+ or Endless fluid. Do you have any brake ducting? If you're running track events you should have brake ducts to cool the brakes off. If you took the brake ducts off an ALMS car they would overheat their brakes in no-time as well. Z calipers aren't the best choice either. For THAT kind of power I would bu running at least a 1.25" thick rotor and prebably 13" even if I could. Google "Defsport wilwood setup". Those, combined with DUCTING, should be PLENTY without the stupid 6-piston calipers. Quote:
Besides, being an asshole makes Zilvia more fun... ![]() EDIT: For the un-informed, the REAL reason why more pistons is better in THEORY is because it distributes the force across the pads more evenly. A lot of calipers actually have larger pistons on the trailing side and smaller on the leading side for the same reason. |
#8 | |
![]() Join Date: Jun 2003
He's running HP+. Not great, but shouldn't fade so easily.
![]() Join Date: May 2008
im running CTS-V brembos with evo rotors and Brembo oem pads.. for the street they are incredible. i am not rich enough to track the car though.. cant attest for how they would handle repetitive high temperature stops. the size of the rotor and the pad material is more important than the caliper itself.
#10 | |
The HP+ should at least work fine to stop the car at the drag strip. They would likely overheat in short order with that kind of power and no ducting on a racetrack though. True, the ONLY reason that I reccomended he change out the Z calipers is because they use 30mm rotors and I would prefer 32mm (1.25") for better heat soak properties. You could also use the R32 GTR Sumitomo calipers with the 32mm rotors. |
#13 | |
Now keep in mind the current s14 wilwood kit come swith a 12.9 rotor and 4 pot caliper. and as I mentioned I right now have a 12.75 (only 0.15 smaller) two peice rotor and 4 pot caliper and it will not slow down a 600hp car quick enough. so Im not exactly confident in the standard wilwood kit. would you be? |
#14 |
Trader Rating: (24)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 24 reviews
It still sounds like you just need to pick pads that work with what you're trying to do.
If you're going to go do a track day you're going to want something like DTC-60s and some ducting. |
#15 | |
![]() They do NOT go hand in hand, AT ALL. The 6-piston version comes with a bigger rotor, THAT will make the brakes more fade resistant. If you put a 4-piston caliper on that same rotor it would have the same fade characteristics. TYPICALLY 6-piston calipers may come with bigger rotors, but that doesn't mean that the 6-piston design is doing anything to increase the heat-soak capacity of the braking system. Also a 6-piston caliper may be larger in size and mass than a 4-piston caliper, which may have a small affect on fade, but that's ONLY because it's bigger NOT the design. You just want the 6-piston brakes to be a badass, just admit it... |
#16 | |
6 pistons.... PER SIDE ![]()
#17 | |
The reason for my inquiry is this. And bare in mind im admitting to not be a brake expert..the civic overall is lighter than a 240. but posibley more front heavy since its drivetrain is up front with the engine. Well I can tell u a 2jz 240 is waaay front heavy! Stop implying that I'm trying to do this for looks. I didn't even say I was committed to wilwoods. I simply asked why they make two types for the Same application. |
#19 | |
All things being equal aside from number of pistons, the fade will be the same. Stop trying to use your particular car to make a point, it doesn't work that way. The different scenarios you're describing don't isolate the number of pistons as the variable. If you have fresh fluid and that system you described, you have an issue somewhere. What rear brakes do you have?
#20 |
Are you talking about Wilwood proper (rather than another company with a kit that uses wilwood calipers)? The civic kits they sell use different caliper lines, DynaPro and Forged Dynalite. The kits vary by over $250 and have different characteristics, the DP calipers are stiffer, heavier, and have bigger pads. Different markets, really. They probably do have better fade resistance, but that's due to the pad area and mass of the caliper, not the number of pistons.
#23 |
![]() Join Date: Oct 2012
So lots of piss here. this is the worst forum on the entire web when it comes to writing shit to people asking questions, nothing gentle at all.
Get the 6piston rotora, i promise it will stop your car. I recently bought the circuit breaker 8 pot from rotora (380mm) and the brakes are very light, havent measured yet but its not much more than stock
Don't PM me asking for parts |
#24 | |
If you want bigger rotors than what you've got the 6-pot setups are pretty much your only option. I think that's overkill, even with that much power, and simply refining the setup you currently have would be sufficient. I'm simply saying that if it's fade you're worried about be concerned with the size oof the rotors, not so much how many pistons the calipers have. That's kind of a back-asswards way of thinking, technically speaking. |
#25 | |
So clearly overall size matters more than piston quantity. Now that I said this. Answer this.. Why does Wildwood have the same smaller brake system for both the 240 and Honda's but offer only the bigger one to the Honda? Is it out of necessity? Are the Honda guys not finding the smaller one adequate and need a bigger? |
#26 | |
#27 |
Motul RBF500 for starters and SS lines all around. The SPL brake deflector would also be a good item to get or fab something like it. You do not need to have a huge deflector, just something to throw more air towards the wheel. You can make the inside of the rotor run too cool with a large deflector. The factory dust shield up front should probably be removed or cut down a lot in your case, it will cause a lot of heat build up and speed up the fading process.
If you want a track proven brake kit, head over to NRR or contact Def on here and ask him about his kits. They use off the shelf Wilwood calipers(which have different size piston areas, to get you to as close to factory bias without having to get a bias adjuster) which are extremely cheap. Pad selection is seemingly endless and are about 1/2-2/3's the cost of factory brake pad replacements.
#30 |
What booster do you have? Manual or Auto?
