Old 03-25-2009, 08:03 PM   #1
jasonrsink
jasonrsink has a spectacular aura aboutjasonrsink has a spectacular aura aboutjasonrsink has a spectacular aura aboutjasonrsink has a spectacular aura aboutjasonrsink has a spectacular aura aboutjasonrsink has a spectacular aura about
ca18det PARTOUT!!!!!!! everything must go
i just found out last friday that i need a new crank and that mine was too messed up to use (couldnt be balanced at all). they also mentioned that the oil pump was bad, probably why i spun the bearing. sucks.
SO, i have decided to part out this motor to all my NICO CA guys. i have already bought a ka24de and dropped it in ( i will be keeping my megasquirt setup as of now, to run my ka with individual throttle bodies : ) !!!!. so this whole motorset is up for grabs now.
ca18det motorset (chosen one's motorset). includes perfect condition transmission. perfect condition nissmo engine and tranny mounts. oem flywheel.all accessories except AC pump and powersteering pump.
-NO: cas, maf, harness (the car was running on megasquirt stand alone), turbo, valve covers, or clutch disc.
motorset has bad crank and bad oil pump.
i have valve covers-$25 (both), and a good condition crank shaft-$75 (from ca sean) available as well.
also, i have a complete side mount intercooler setup with complete metal (not oem plastic) piping and turbo xs blow off valve welded on-$50.
i have a brand new oem headgasket as well available-$40.
also i have a buddy selling a powersteering pump and bracket $80 shipped if needed.
PART OUT PRICES:
rods/pistons $125 ($55 rods, $75 pistons)
flywheel metal covers $25 (both)
oem flywheel $25
oil pan with silicone hose $60
oil pan girddle $20
oil pickup $15
complete head $100 (will break down head if people need head parts) *SOLD*
empty block $50
coilpack cover (its blank CNCed aluminum) $20
starter $65
alternator $60 *SOLD*
injectors/rail $45
good condition crank $75
valve covers $25 (for both)
waterpump $35
head cam cover $10
upper timing belt cover $20
lower " " " $10
cams oem $50 (each) *EXHAUST CAM SOLD*
cam gears $20 (each)
intake manifold $75 (will sell upper for $60, lower for $40, throttle body $30)
exhaust manifold $25
transmission $75
pressure plate $25
flywheel cover plate $20
nissmo motor mounts (perfect) $75 *SOLD*
nissmo transmission mount/bracket $50
headgasket oem $40 *SOLD*
tps sensor with clip and wiring $20
t25 turbo (very slight shaft play, smokes a lil) $75
engine to tranny mounts $10 (each)
engine mount mounts to block (part that engine mounts sit on attached to block) $10 (each)
EVERYTHING IS OBO,
its all used, but i feel these are VERY fair prices. i have checked other ca partout threads to determine my pricing. all my prices are 5 to 10 bux lower than everyone else on average.feel free to call me out if you feel a price is unfair too. i want all of this stuff gone ASAP : )
i will do even lower prices if someone wants multiple items.
first come first serve.
pm me, call or text me 8134586240 if you need something else, or have questions : )
jason sink
will ship anywhere
paypal accepted [email protected]
jasonrsink is offline
Old 03-28-2009, 11:02 AM   #2
jasonrsink
bump
bump bump bump
Old 03-29-2009, 01:35 AM   #3
rei_k's
rei_k's is an unknown quantity at this point
I need this cover.
http://i168.photobucket.com/albums/u...2/100_0895.jpg
rei_k's is offline
Old 03-31-2009, 12:56 PM   #4
jasonrsink
Originally Posted by rei_k's View Post
gotcha 20 bux 8134586240 call or text
Old 04-01-2009, 02:58 PM   #5
jasonrsink
bump bump bump
Old 04-07-2009, 02:31 PM   #6
jasonrsink
bump bump bump[
Old 06-22-2009, 07:20 PM   #7
EP2009
EP2009 is an unknown quantity at this point
do u still have parts ?
EP2009 is offline
Old 11-20-2013, 02:47 PM   #8
914Slide
914Slide's Avatar
914Slide can only hope to improve
do you still have the water pump ! pm asap
914Slide is offline
Old 11-21-2013, 01:08 PM   #9
g35gabby
g35gabby's Avatar
Trader Rating: (26)
g35gabby is an unknown quantity at this point
Feedback Score: 26 reviews
This is from 2009!
PS you can get a new water pump at any auto parts store....
g35gabby is offline
Old 12-27-2013, 10:51 AM   #10
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
THREAD LOCKED! Take notice of the original post date before bumping something from the dead!
dorkidori_s13 is offline
